Dash problem
Old Dec 22, 2007 | 10:14 AM
spanishvette86's Avatar
spanishvette86
Default Dash problem
Hi all!!. I´m a new forum member. Nice to meet u all.
Im spanish, so its my english isnt good (sorry ). I have an 86 corvette.
Well, my problem is at the dash panel. I can see it when the sun is shining, but i cant at night. So, it works, but i dont have light in it.
The intermitence lights and large lights are allways on in the panel. I know that the problem arent the bulbs.
Anyone of u knows what hapens??. Thanks and excuse my english
Later i will show u a picture.
Old Dec 22, 2007 | 11:17 AM
jfb's Avatar
jfb
There are four lamps in the cluster (speedometer, tachometer, oil pressure, battery volts). They are #882 lamps and you can replace them by removing the dash cover. The lamps are quartz-iodine lamps and cost about $12 each. You will see four silver caps over the lamps. Remove the covers and remove the lamps by wrapping a piece of tape around the lamp and stick the ends together. Then use a needle nosed pliers on the tape end that is stuck together and pull straight out, make sure you do not turn the lamp. The lamp has straight pins but is in a socket that turns. If you turn the socket, it will fall into the cluster housing and you will have to remove the cluster to retrieve and replace the lamp and socket. Use a piece of tubing over the new lamps to install the lamp. If you touch the lamps, after installation use some alcohol and a Q tip to wipe the lamps because your fingerprint on the lamps will shorten their life.
Old Dec 22, 2007 | 12:32 PM
spanishvette86
Thanks!!, but i think the bulbs arent the problem. I saw it and they looks fine. I think there is any wrong connection, because intermitence lights(i think this is the correct word), and long lights signal, are allways on. I bought this car 4 months ago, and the owner told me that all the cluster works right. The car was in a repair center, and they gave me the car with that problem.
Any connection, i think. The 2 lights above the legs doesnt work too. And the bulbs are new.
Old Dec 22, 2007 | 01:01 PM
spanishvette86
[/IMG]
Well, that left and right lights, are allways on. And center (long light) too.
Thats the reason cause i think theres any connection wrong. Dont u think iit?. Thanks for your help
Old Dec 22, 2007 | 01:09 PM
Jeffwilson34's Avatar
Jeffwilson34
I had the same problem.
look at this post.
http://forums.corvetteforum.com/show....php?t=1894110
Old Dec 22, 2007 | 02:33 PM
spanishvette86
look at this post.
Ok Jeff. Thanks my friend. Ill try to translate it and to find that firewall connector. Thanks
Old Dec 23, 2007 | 09:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Looks like Jeff's thread is what you needed.
Here is a section from my 86 service manual. Save it to your computer, it may come in handy, later.
http://members.shaw.ca/agent86/Instr...%20Cluster.pdf
Old Dec 23, 2007 | 11:02 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
http://www.batee.com/corvette/index.shtml
Old Dec 23, 2007 | 03:15 PM
spanishvette86
Thanks Mr Agent. Someone told me about u here in Spain. U are famous!!
I have a conflict with my Firefox, and i cant download it.
Could you send it to jabisv@yahoo.es, please?
Its a pleasure to meet u. Thanks for all.
Old Dec 23, 2007 | 03:16 PM
spanishvette86
Originally Posted by xccter
Thanks xccter!!
Old Dec 23, 2007 | 03:27 PM
AGENT 86's Avatar
AGENT 86
Email sent
You need Adobe PDF reader or similar, to open the file.
Old Dec 24, 2007 | 07:53 AM
AGENT 86's Avatar
AGENT 86
I sent you 14 emails with the original scans. I suggest you find out why Firefox refuses to open the PDF's, because I'm sure you will be looking for more info.
Merry Christmas
To Dash problem
