Remote Mirror Problem
Old Dec 25, 2007 | 02:37 PM
garypamc4's Avatar
garypamc4
1st Gear
Default Remote Mirror Problem
I have a 1986 Coup and the driver side remote mirror isn't working. Any suggestions?
Old Dec 26, 2007 | 02:00 PM
GIMMESOME's Avatar
GIMMESOME
Could be quite a few things.But I would start with testing the rocker switch that switches from left to right mirrors,then work your way to the joystick checking for power.This will require removal of the center console,that's not too hard,and seems like the easiest place to start.My 86 had the same problem with both mirrors being intermitent,but that was a poor contact on my fuse holder.Good luck.
Old Dec 26, 2007 | 05:48 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I had a similar problem. It turned out to be a bad rocker switch that switches from left to right mirrors. Once I replaced it, all was well.
Old Dec 26, 2007 | 06:08 PM
trulytex's Avatar
trulytex
I had the same problem, but it was the motor in the mirror. One of the gears was froze up. I removed the glass and manually unfroze the gear and oiled it with WD40 and it worked fine afterward.
Old Dec 27, 2007 | 05:58 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
how do you remove the glass?
Old Dec 27, 2007 | 06:22 PM
Happydad's Avatar
Happydad
Old Dec 28, 2007 | 04:50 AM
trulytex's Avatar
trulytex
Gently grab the glass on both sides and pull - it pops right out.
Old Dec 29, 2007 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Power%20Mirrors.pdf
Old Dec 29, 2007 | 12:44 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Does it just pop back on??? Any special tips for removal and reinstallation?
Old Dec 29, 2007 | 03:26 PM
trulytex's Avatar
trulytex
Yes, it just pops back on. Just be gentle. When you reinstall, just press in the middle of the mirror glass. When you remove the glass, it will be evident how to put it back on. No Big Deal. The little gear was just froze on mine - it would go left/right but not up/down. I just rolled the gear between my thumb and forefinger to free it up, then added a little WD40. Try it, it's a quick and easy test.
To Remote Mirror Problem
