side pipes
Old Jan 27, 2008 | 02:19 PM
wooka's Avatar
wooka
Default side pipes
I would like to put pipes on my 91 coupe,,any suggestions?
Old Jan 27, 2008 | 02:25 PM
VETTEHIGH's Avatar
VETTEHIGH
Go for it , would look great . Thought about that for my C4. If so, have them JET-HOT coated in sterling
Old Jan 27, 2008 | 02:27 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Do a search on this forum. The one company that made them, SidEffects" apparently is no longer in business.
Old Jan 27, 2008 | 04:54 PM
GS348's Avatar
GS348
Default Good Luck...
There are quite a few forum members that have posed this same question. If you're patient, I'm sure something will be available, but I'm pretty sure unless you find someone that suddenly wants to change the look of their sidepipes that they currently have you may have to get creative and try fabbing up something on your own. If you go that route, best of luck.
Old Jan 27, 2008 | 05:25 PM
StealthLT4's Avatar
StealthLT4
I think you're best off trying to fab something. The Side-Effects kit looked fairly restrictive, and wasn't even a true side-exit (it wend to the rear axle, then out 90* to each side). I think if you were able to pull off something C3-esque, it would be really cool.
Old Jan 27, 2008 | 07:30 PM
SuperL98's Avatar
SuperL98
I was thinking about fabricating some real side pipes too.
I have been collecting body parts to put my car back to stock ...
But first, thought I might go way over the top with something like this
Old Jan 27, 2008 | 07:36 PM
rodj's Avatar
rodj
Buy earmuffs
Fun for a while but can be annoying drone at cruise speeds.
"I think if you were able to pull off something C3-esque, it would be really cool."
Problem is getting the headers out of the engine bay;
No room to go over frame rail and underneath would be seriously low to the ground
Old Jan 28, 2008 | 10:33 PM
Jim Nichols's Avatar
Jim Nichols
Check photos in my profile. 91 Coupe
Old Jan 29, 2008 | 09:53 PM
Gramps96's Avatar
Gramps96
Try powereffects.com. Will run you around $2K.
To side pipes
