Help
Old Jun 6, 2008 | 08:18 PM
wnaberacing's Avatar
wnaberacing
Default Help
This is my first rear brake job on a C-4. I guess I'm a dumb @#!. How do I get the piston back in the caliper? Thanks
Old Jun 6, 2008 | 08:54 PM
mechguy79's Avatar
mechguy79
Big damn C-clamp! If your C-clamp is big enough you can even use one of the old brake pads between the piston and clamp to push the piston in. The pad helps distribute the pressure from the clamp. You don't need to use it if you don't have the room. Also, if you haven't done it already, you can turn your steering wheel all the way to one side or the other to point the brakes outward. That makes them WAY easier to reach. Good luck!
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Not a dumb question if you haven't done it before.
Leave the old pad on the piston and use a C-clamp to squeeze it back into the caliper until it stops.
Old Jun 6, 2008 | 09:04 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You might want to remove some fluid from the reservoir, before you compress the piston into caliper.
Old Jun 6, 2008 | 09:05 PM
wnaberacing
I'm an idiot. I got it. Thanks guys.
Old Jun 6, 2008 | 09:27 PM
Bill Cude's Avatar
Bill Cude
Tony, it sounds like your having fun !
To Help
