Engine Cutoffs
Old Jul 11, 2008 | 09:17 PM
rwynn's Avatar
rwynn
Default Engine Cutoffs
I have a 1986 4+3 and everytime you apply a lot of pressure to the brakes the car cuts off. It cuts off while idling and while driving. I replaced the master cylinder and the brake booster. Anyone have any thoughts, or could the new booster be bad also.
Old Jul 11, 2008 | 10:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
New to you with old problem or old to you with new problem ??
Old Jul 12, 2008 | 07:18 AM
rwynn's Avatar
rwynn
I have owned the car for 45 days. Has been doing it since I brought it.
Old Jul 12, 2008 | 08:01 AM
AGENT 86's Avatar
AGENT 86
The motor will die when your sitting still and you apply the brakes ??
Do your hear a vacuum leak when you apply the brakes ??
Old Jul 14, 2008 | 08:05 AM
rwynn's Avatar
rwynn
It cuts off while idle also while driving, more when I am pulling into a parking lot and braking it cutts off. I can make it cut off when idling by just pushing the brake. The rpms when drop and it cutts off.
Old Jul 14, 2008 | 08:56 AM
AGENT 86's Avatar
AGENT 86
Plug the vacuum hose to booster and see if you can kill it at idle. If you can, you can rule out the booster.
Have you tried to set the minimum idle and re-adjust the throttle position sensor, according to the factory service manual ??
Old Jul 14, 2008 | 10:10 PM
rwynn's Avatar
rwynn
Actually it only cuts off when the vacuum hose is plugged into the booster. I have not re-adjusted the sensor yet.
Old Jul 15, 2008 | 01:17 PM
staugur's Avatar
staugur
The IAC unit should prevent the car stalling out.Perhaps that's worth a look at.If it is the problem, the $29 NAPA unit worked fine for me.
Old Jul 15, 2008 | 06:05 PM
rwynn's Avatar
rwynn
Thanks I will give that a try.
Old Jul 15, 2008 | 07:38 PM
AGENT 86's Avatar
AGENT 86
Cheaper to diagnose the IAC. http://members.shaw.ca/agent86/IAC.pdf
You might want to spend the time and pull the TB, remove the IAC and clean the passages and bores. Re-install and then re-set the minimum idle and TPS. https://www.corvetteforum.com/techti...D=55&TopicID=2
Old Jul 15, 2008 | 11:57 PM
Lichen's Avatar
Lichen
If your new booster is an A1-Cardone from Autozone, that may be your problem. They are CRAP!
Old Jul 20, 2008 | 02:25 PM
rwynn's Avatar
rwynn
I changed the idle control unit and it did help a little. I am being told now that it is the vacuum. The cams were changed by the previous owner. I am told I need a vacuum canister in line with the brake booster.
Old Jul 21, 2008 | 06:22 PM
rwynn's Avatar
rwynn
I will check with my mechanic tomorrow. Is there something written on the booster that you know of?
Old Aug 1, 2008 | 03:58 PM
rwynn's Avatar
rwynn
I addedm the vacuumm canister and it did not help at all. I am now being told I have a vacuum elak somewhere. Does anyone know where to find a vacuum diagram for a 86.
To Engine Cutoffs
