C4's really do fly
Old Jan 3, 2002 | 03:40 PM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: C4's really do fly (Aquaman93)
I think I actually landed softer because I was going so fast that the momentum carried me forward so I didn't just drop.
Simple physics says horizontal and vertical velocity is unrelated. You landed soft because you didn't get very high.
But what do I know, I'm only a teenager. :D
Old Jan 3, 2002 | 03:50 PM
TurboLuigi's Avatar
TurboLuigi
Default Re: (scorp508)
Scorp,
Good shot there. Kinda gives new meaning to the term Ground Effects.
Luigi
:cool:
:chevy
Old Jan 3, 2002 | 03:54 PM
NoWorries's Avatar
NoWorries
I'll leave my flying to the whirly birds.(See sig)
A C4 aerodynamically can't fly, not without an underbody kit at least. :)
Old Jan 3, 2002 | 03:56 PM
scorp508's Avatar
scorp508
What if you reverse the tranny and go backwards? :)
Old Jan 3, 2002 | 04:01 PM
NoWorries's Avatar
NoWorries
Default Re: C4's really do fly (stormy652)
Simple physics, yes, but not advanced. There is a lot of aerodynamics going on, such as the C4 looking somewhat like an air-foil, and the rebound of the springs/shocks.
I don't claim to know how a C4 would fly, but there is a lot more going on than V1 and X1.
Old Jan 3, 2002 | 04:02 PM
scorp508's Avatar
scorp508
I was just kiddin' :) I've been through pilot ground school, just can't afford the flights tests. :sad:
Old Jan 3, 2002 | 04:04 PM
NoWorries's Avatar
NoWorries
Since reverse is such a low gear, you'd top out at around 30 mph, no where near rotation speed!
Old Jan 3, 2002 | 04:25 PM
scorp508's Avatar
scorp508
Default Re: (NoWorries)
I said reverse the tranny, not put it IN reverse. :)
Old Jan 3, 2002 | 06:57 PM
GTB's Avatar
GTB
I had a coil over suspension on my car last year, and went over a construction spot on a road at about 75.
I went air born, and cracked my head harder than he$$ on the top, too.
:crazy:
Old Jan 3, 2002 | 09:29 PM
91Vette's Avatar
91Vette
130 mph and airborn ?? Man, you got big ones!!!!!!!!!!
Old Jan 4, 2002 | 02:56 AM
GlockLT4's Avatar
GlockLT4
Default Re: C4's really do fly (91Vette)
Uhh.. if you go air borne.. you better freakin' have your wheels facing the direction that your car is traveling! .. or you're going to have some big problems!
Old Jan 4, 2002 | 08:47 AM
Grand Trunk's Avatar
Grand Trunk
Veteran: Marine Corps
Am I the only one that thinks that's a photochop?
Old Jan 4, 2002 | 09:44 AM
  #33
vallini's Avatar
vallini
Default Re: C4's really do fly (vettes rule)
Took my Vette airborne (not intentionally) when I was zipping down at about 120mph on a local 4 lane highway. I hit a slight crest in the road and bottome out my driver's side front wheel. Even though the car has been repainted since then I have a nice rub mark from where the tire hit inside the fender well on the backside of the hood. The car gets a little squirrely when it lands at and angle like that. :jester
Old Jan 4, 2002 | 10:30 AM
  #34
your drinking buddy's Avatar
your drinking buddy
Cruise-In V Veteran
Cruise-In VI Veteran
:yesnod: Another teenager in physics :cheers:
Old Jan 4, 2002 | 01:42 PM
  #35
lemans396's Avatar
lemans396
What type of wheels are on the airborne vette?
Old Jan 4, 2002 | 01:50 PM
  #36
scorp508's Avatar
scorp508
Default Re: C4's really do fly (JJB)
Why?
Old Jan 4, 2002 | 06:20 PM
  #37
Grand Trunk
Default Re: C4's really do fly (scorp508)
I'm just looking at the tires where they would normally contact the road surface, particularly the left rear. It sorta looks to me like the bottoms of those tires could be sitting on something. It may just be the angle. The shadows on the ground seem real enough tho.
Nevermind...I just noticed the suspension appears fully extended.
We now return you to our regularly scheduled programming....
Old Jan 5, 2002 | 11:03 AM
  #38
RogueVette's Avatar
RogueVette
Default Re: C4's really do fly (vallini)
Took my Vette airborne (not intentionally) when I was zipping down at about 120mph on a local 4 lane highway. I hit a slight crest in the road and bottome out my driver's side front wheel. The car gets a little squirrely when it lands at and angle like that. :jester
Yeah I was fortunate to land pretty even both times no one was behind me on my first flight so I don't know how high I got but those that were behind me on my next trip all said I had about a foot of air under the tires. I had the petal to the floor both times and ASR off so like I said when I landed the rears broke loose for a second kickin' the A S S about a foot to the right. I wish I could have seen it it had to look way cool :D :eek: there was another time where We (Dowell and I) were going about 65 and we crested a peak that extended the suspensions on both cars that was actually a harder jolt then the the times I got off the ground(physics or not). still no damage though. I have since put about 1000 miles on the car and all seems well. however I think i'm done with doing that since I never get lucky more then twice ;) next time I'll probably loose it and end up in a tree :rolleyes:
[Modified by Aquaman93, 9:06 AM 1/5/2002]
