snookman4
Old Aug 25, 2008 | 09:13 AM
snookman4's Avatar
snookman4
5th Gear
Default snookman4
Hi guys, I am new to corvette forum (first post) and new to corvettes. 87 C4 coupe. Starting having problems yesterday with the clutch being very hard to push in initially, then it clicks and readjusts itself somehow and works normally until you let it all the way out. Then the process starts over. Has anyone here experienced this? Thanks for any advice!
Old Aug 25, 2008 | 11:37 AM
betyelou's Avatar
betyelou
Welcome to the forum, I'm sure someone has had this problem and will help you with it.
Old Aug 26, 2008 | 09:34 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Welcome aboard
Is the clutch master cylinder, full ??
Your description sounds familiar. When I installed my new motor the clutch fork(pivot socket) got pushed off the ball stud. I pulled off the boot and manipulated the fork back onto ball stud.
Worth a look.
Old Aug 26, 2008 | 02:46 PM
snookman4's Avatar
snookman4
5th Gear
Default master cylinder
Thanks, I will check the cylinder. the clutch pedal actually seems to be a bit higher than it's supposed to be. The clicking and the easier operation has stopped now, it just pushes in hard all the time now. Problem started afternoon before yesterday.
Old Aug 26, 2008 | 04:28 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
Welcome to the CF! Other than the clutch fluid level I have no more ideas to help.
Maybe a guy like cruisinartvette can help you out.
Old Aug 26, 2008 | 04:58 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum, and good luck with your problem..
To snookman4
