Powdercoat headers?
Old Feb 12, 2009 | 04:38 AM
lil_Mike's Avatar
lil_Mike
Default Powdercoat headers?
just got a new set of headers and i wanna either wrap them or coat them or something.
would powdercoating be strong enough? does it hold heat well or will it chip/crack off?
Old Feb 12, 2009 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Powder coated paint would turn to crap in no time, unless the powder was made of ceramic.
Old Feb 12, 2009 | 08:31 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
http://www.jet-hot.com/
Old Feb 12, 2009 | 11:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yep, Jet Hot or similar ceramic coating in & out is the only way to go with headers...
Old Feb 12, 2009 | 02:37 PM
lil_Mike's Avatar
lil_Mike
yeah i know its the only way but too pricey for me right now. i know powdercaoting isnt as expensive. i jsut wanted to know if it would withstand the heat and that?
Old Feb 12, 2009 | 07:36 PM
c4cruiser's Avatar
c4cruiser
Powdercoating is cured in a 450 degree oven. The headers will easily exceed that temp so the chances are good that the heat will cause flaking of the coating.
You should talk with a powdercoater to see if there are hi-temp coatings that will work. But I 'm betting that a ceramic coating like Jet-Hot will be your best alternative outside of a high-heat paint.
And don't use a header wrap. The material will hold condensation after the headers cool down and you WILL get rust.
Old Feb 12, 2009 | 07:38 PM
mgbss's Avatar
mgbss
I understand that a ceramic is available for the powder coat guns like eastwood and other home type guns. I have seen pictures of a set a guy did for a V-6 Mgb they looked good and he said he had done them himself, I think just on the out side though.
Joe
Old Feb 13, 2009 | 05:15 PM
john chsnut's Avatar
john chsnut
The powder coater will tell you that they have a high heat coating suitable for headers. I tried it on one set and it didn't hold up well at all. I use Ceramic coating on all of my headers/sidepipes now with good results. The silver color polished for my combo cost about $450 but in Ceramic black it is only about $300. For just headers the cost would be about half. This is a good investment to protect your headers.
Old Feb 13, 2009 | 05:23 PM
Iroc57's Avatar
Iroc57
And if your talking around $200ish it will be a deal. You will spend around $80 just to wrap them
Old Feb 13, 2009 | 08:13 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
My coated EM headers
To Powdercoat headers?
