help me plz im begging?
Old Mar 17, 2009 | 04:20 PM
bangand0lufsen's Avatar
bangand0lufsen
Default help me plz im begging?
so i have had trouble with my pop up headlights and i found out whats wrong its not bushings or gears but this part
the silver part the shaft is spinning inside its housing so when it trys to move the headlights it just sits there and the gear and the housing moves around the shaft!!! anyone know how to fix this iv been trying to fix it for over 8 months now and just figured out whats causing it but have no idea how to fix it!!!
Old Mar 17, 2009 | 04:44 PM
CAJUN C4's Avatar
CAJUN C4
I'm not familiar with that part. But,Advance Autu sells a complete new motor for about $85.00
Hope this helps
Old Mar 17, 2009 | 08:19 PM
larry00's Avatar
larry00
I live in FW and I put gears and bushings in my 95 . I will be in town soon if you don't get some help I can look at it.
Does the manual **** move the light's ?
I put the bronze gear in mine cause someone said that very thing would happen eventually.
There is a headlight repair sticky in the tech section.
Do you hear any sounds ?
Old Mar 18, 2009 | 09:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Can you see anyplace that a split pin or rolled pin is installed ?? Has it sheared ??
I'm not familiar with those parts, but it looks like you could drill it and install a split/rolled pin, to stop the spinning.
Old Mar 18, 2009 | 09:43 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Can't help with your immediate problem. For the future and for other C4 owners though do this comparison.
On you next trip to the auto parts store grab 2 different replacement headlights off the shelf. One plastic, the other glass. Lift one with each hand and feel the amazing difference in weight.
Replace your glass bulbs with the plastic ones. This will prevent future problems with your headlight motors in the future.
Per Gordon Killebrew. If you newbies don't know who he is then go to www.gordonkillebrew.com
Old Mar 18, 2009 | 12:53 PM
bangand0lufsen
no pin sadly and i wish i could drill it but living in an apt now i have no drill press any more im at a loss of what to do to fix it now
Old Mar 18, 2009 | 02:05 PM
Z51JEFF's Avatar
Z51JEFF
When I went through the headlight motors on my car I found it odd the headlights were plastic until I figured the light weight would put less wear on the assembly.In the picture from the OP there should be a pin in the shaft that keeps the gear from spinning on the shaft.
To help me plz im begging?
