Windshield
Old Mar 18, 2009 | 09:07 PM
TheWildcat's Avatar
TheWildcat
Default Windshield
does any one have a drawing of the windshield assembly for an 89 vert? thanks JOHN jjrace90@aol.com
Old Mar 18, 2009 | 09:36 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
??? Not sure of what you need. Maybe if you said what you'tre doing.
Old Mar 18, 2009 | 11:55 PM
TheWildcat's Avatar
TheWildcat
Default sorry
I want to change the windshield in my 89 convertable... I can buy the glass for $125... I have new weatherstriping already... what else will I need? and should I tackle it my self.. thanks JOHN
Old Mar 19, 2009 | 12:13 AM
5POINT7's Avatar
5POINT7
you can thank me later
Old Mar 19, 2009 | 12:45 AM
zr1fred's Avatar
zr1fred
It depends. If you want to put the foam/mylar back on, you will need to buy that from GM ($$). Most people reuse it if they can, or just do without it. Be very carefull and deliberate when you take off the three pieces of metal trim from around the windshield. If it hasn't been replaced before it can be a problem (they bend very easily) There are screws hidden under the two side pieces (small head philips, that require you to separate the side trim (they are glued together with the above mentioned foam/mylar). You probably already know this, but the trim pieces are screwed to the windshild pillar underneath the weatherstip.
Old Mar 19, 2009 | 01:17 AM
TheWildcat's Avatar
TheWildcat
Default thanks
Thanks Fred
To Windshield
