86 Antitheft
Old Apr 7, 2009 | 01:59 PM
clambake0000's Avatar
clambake0000
8th Gear
Default 86 Antitheft
I bought an 86 with no manual. The antitheft keeps going off.
I would like to disable it but do not know the location in the car, can anyone help me know where to look?
Old Apr 7, 2009 | 02:02 PM
jackcasa's Avatar
jackcasa
Post this on the C4 forum for better response.
Old Apr 7, 2009 | 02:04 PM
danl72's Avatar
danl72
Old Apr 7, 2009 | 02:12 PM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
Hey...I just had my '86 stolen and kept the manual in my house...
J/K!!!
Old Apr 8, 2009 | 08:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Explain "going off", when your not in the car or when you enter the car ??
Read this http://members.shaw.ca/dankai/Vats%20Electrical.pdf
Knowing how it's armed and disarmed, may solve your problem.
Oh, and when you say "antitheft", I'm assuming forced entry alarm (horn)
Old Apr 8, 2009 | 08:39 AM
flynn508's Avatar
flynn508
I just bought a new '86 manual, and all it really says is that to arm the system, lock the doors, to unarm it, unlock the doors with the key, or start the car with your VATS key. The manual doesn't specifically troubleshoot anything like it 'going off', and doesn't say where the 'hardware' is. Can you disarm the system with your key? Is anything specific making it go off, or is just going off at random? I do not believe there is any motion sensors like in my Audi, so this could be yet another issue with the door ajar switches (see my thread-'interior lights staying on'). If the doors are locked and the system is armed, and if the door ajar switch is failing, making the car think the doors are open, then maybe that is what is setting off the alarm. Can you just leave it unlocked for now, an not arm the system?
Old Apr 8, 2009 | 09:27 AM
steven mack's Avatar
steven mack
If you can't track it down there is a company on ebay that sells a chip to disable it among other changes if you want them for $79.
Old Apr 9, 2009 | 09:02 AM
clambake0000
8th Gear
Thank you for taking the time to help. After reading your response and some info. the I found on google I found out that if you don`t turn the key as far as possible to the left before pulling the key it will go off when just opening the door. This seems to have helped at least for now. Thanks again.
Old Apr 9, 2009 | 09:05 AM
clambake0000
8th Gear
Thanks, I found out that the drivers side lock was not turned all the way before pulling the key. If I do that it seems to work OK, maybe it is worn some.Thanks again
To 86 Antitheft
