Clay bar?
Old Apr 21, 2009 | 03:12 PM
  #41
Joevette86's Avatar
Joevette86
Clayed the car today Cloudy and cool ,perfect day for it. Though my paint job is only 5 years old, the clay took out a lot of the contaminents I could not get otherwise. The finish is smooth and glass like. I did the whole car other than the wheels. I took some before and after photos and there is a subtle difference in the pictures. But ,I don't need the photos to see it myself. I have been converted. The clay bar instructions mention the clay can be used for 10-12 applications but I wouldn't use it on the Vette again. I'll do my wifes Maxima then throw it out
It doesn't look or feel like it needs to be waxed but i'll probably wax anyway now that the surface is clean.
Thanks for the tip on this forum.........I had never even heard of the clay bar before.
Old Apr 21, 2009 | 03:35 PM
  #42
Square's Avatar
Square
You absolutely should put a wax or polish on your car. The clay bar will remove contaminants from your paint, but your now "contaminant free" paint surface needs protecting.
I prefer Zaino for it's durability, but any good wax/polish will do.
Old Apr 22, 2009 | 01:04 PM
  #43
Joevette86's Avatar
Joevette86
Spoke with an auto detailer today about using Zymol to wax.He suggested Collinite 915 which is better/cheaper and lasts longer. Being an amatuer "waxer?" I went with his advice ,checked it out on the web after buying it and can only find good things about it. Cost:23.00. Zymol....$71.00 . I'll check back with the results if it ever stops raining enough to get the Vette out of the garage At this point I'll leave it in the garage until it's a good day. For me it's a weekend car anyway and clean as a whistle right now
Old Apr 22, 2009 | 01:52 PM
  #44
mguerra's Avatar
mguerra
Finalist 2020 C7 of the Year -- Unmodified
I use the clay bar kit from Griot's too (although I use all the other Zanio wax products). It works well. Put on a latex glove on your hand and glide it over the car before and after you clay bar it. You'll notice the glove will catch on the embeded dirt before you clay it.
Good luck!
Old Apr 22, 2009 | 03:11 PM
  #45
Alan777's Avatar
Alan777
Zymol is overpriced imo. it really hasn't changed from the original formula, and there are much better alternatives that give good shine.
poorboys Natty is an awesome paste wax, and only $20/tub. Poorboys EX/EX-P is also an excellent choice. For a sealant, can't go wrong with the duragloss lineup
Alsoa good way to tell hoe bad your car needs clayed is to wash it, then put your hand in a plastic bag and feel the paint. It "amplifies" all the embedded grime and dirt.
Old Apr 22, 2009 | 03:53 PM
  #46
Larry/car's Avatar
Larry/car
My question is, how much of the clear coat are we removing when you use clay? When you polish some of the finish is removed. Does Clay remove more or less than polishing compound? I haven't tried this method as yet, will experiment on my truck first.
Old Apr 22, 2009 | 04:04 PM
  #47
my83432's Avatar
my83432
None, it just grabs anything that is sticking out of it. That's why it is so important to wax the car after you are done. The wax seals off the holes from where the bits were remove from.
Old Apr 22, 2009 | 04:28 PM
  #48
Larry/car's Avatar
Larry/car
I'll have to give it a try.
Old Apr 22, 2009 | 05:06 PM
  #49
Alan777's Avatar
Alan777
yeah, clay only removes contaminants from the clear, it doesn't remove clear liek buffing or wetsanding
Old Apr 22, 2009 | 05:22 PM
  #50
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I'm going to try mine in a week or two (time issues)
I did wax my wifes Camry last week though so that when I get ready for the vette and my Caddy, she can't scream at me "what about my car"
Old Apr 22, 2009 | 06:12 PM
  #51
F1Fan's Avatar
F1Fan
I think that being wax brings out more of a glow and the synthetics will give more of a mirror reflection. I like the other benefits of Zaino too, like the UV protection and the layering, which wax will not do.
Old Apr 22, 2009 | 07:54 PM
  #52
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Does anyone, other than Griot's, sell just the clay bar? I've seen the Meguiar's kit at Auto Zone, but I already have a large bottle of thier spray on detailer, and don't need any more right now.
Old Apr 22, 2009 | 08:37 PM
  #53
mguerra's Avatar
mguerra
You can buy just the clay from Griot's...$19.99 for 8oz.
Old Apr 22, 2009 | 09:08 PM
  #54
Klondike's Avatar
Klondike
I've used both the Meguiars and the Mothers clay bars and both do an amazing job. I think I like the mothers a little better, it seems to be a little more sticky and holds together a little better with use. After washing and claying, the paint is so slick it's like a new piece of glass. I (wax) with an aircraft finishing coating called "Rejex" and it is so shiny and deep it is unreal! It's so slick that nothing will stick to it! The car cover will even slide off if it isn't centered and tied on!
Old Apr 23, 2009 | 10:28 AM
  #55
Joevette86's Avatar
Joevette86
As far as what clay bar is better....the owner of a detail shop said to me ,all are the same and come from Asia.(I had many questions for him when I got my supplies) All the clay bars I saw are blue. Maybe some other colors are out there but I didn't see any if it makes any diff. Apparently clay from here is a different consistency and does not remove contaminents and may also be harmful to a car. He seemed knowledgable to me and steered me away from some of the more expensive brands. This is how I ended up with Collinite 915 which I will be using today.
Old Apr 23, 2009 | 12:42 PM
  #56
Joevette86's Avatar
Joevette86
Done with waxing and the Vette hasn't looked this good in a couple years
Old Apr 23, 2009 | 03:00 PM
  #57
seajayiii's Avatar
seajayiii
Mine's next ....
Old Apr 23, 2009 | 03:06 PM
  #58
RetiredSFC 97
Old Apr 23, 2009 | 03:15 PM
  #59
mguerra's Avatar
mguerra
We've got ourselves a picture thread!
Clayed and Zaino'd last week...
