Power Steering Fluid
Old Apr 13, 2009 | 11:05 AM
AstroMan1's Avatar
AstroMan1
Default Power Steering Fluid
This is what a local GM Goodwrench center power steering fluid flush looks like after 50 miles???
Old Apr 13, 2009 | 11:25 AM
my83432's Avatar
my83432
Looks just like mine.
Old Apr 13, 2009 | 01:16 PM
vader86's Avatar
vader86
Yep, they'll turn black. Best to get it out once it does go that way, which is why a flush is preferable to just sucking it out and replacing.
Old Apr 13, 2009 | 03:10 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You got the shaft
Old Apr 13, 2009 | 09:11 PM
RedVette84's Avatar
RedVette84
Not Good.
Old Apr 14, 2009 | 07:57 AM
AstroMan1's Avatar
AstroMan1
I took it back to the dealer and they said they "knew they had flushed it". They offered to do it again no charge and are checking on the price of a steering rack. I had them see if they could put the Z51 option on. It's very dangerous, I was lucky the car had problems when I picked it up from the service the first time, so I knew something was up before I started driving. Imagine being out on the road going 128 and the power steering goes out, then you pull on it really hard and all of a sudden it starts working again and you really oversteer. This happened at low speed on the way home from the dealer and it was quite exciting.
Old Apr 15, 2009 | 10:20 AM
AstroMan1's Avatar
AstroMan1
I think I figured out what happened. The dealer said they "knew they flushed it", so I think when they hooked it up and ran the flush through it, it didn't rinse. That's why the fluid is still so black and full of dirt and, the flush contaminated my power steering fluid so that I am having trouble with the power steering. I will be getting it flushed tomorrow free of charge and I bet I won't have to get another steering rack.
Old Apr 17, 2009 | 10:53 AM
AstroMan1's Avatar
AstroMan1
Wrong guess. Guess my power steering rack is leaking. Even the mechanic who just put my B&B cat back said. The dealer wants 890.00 for the whole thing installed. That's probably the way I'll go but, I wonder if GM has fixed the thing with the sleeve and the piston now? Are there any better alternatives?
Old Apr 17, 2009 | 11:25 AM
engle1147's Avatar
engle1147
Originally Posted by Michael Rine
........................................ ................................Yummy!
Old Apr 17, 2009 | 01:03 PM
runner140*'s Avatar
runner140*
I see he kept it in a "Ball" jar.....he's planning on keeping it.
Old Apr 17, 2009 | 09:35 PM
DanZ51's Avatar
DanZ51
I did mine years ago. I picked up a reman rack from NAPA, Z51 ratio (I knew the owner ). Most of the rebuilts have a steel sleeve the piston runs in, the original equipment didn't thus wore poorly. I don't know if the new GM units are steel sleeved (I wouldn't count on it).
As far as the flush, I think you're wasting your time/money. I have to ask, why did you drag your C4 to a dealer?
To Power Steering Fluid
