Headlight question????
Old May 20, 2009 | 03:24 PM
joescvette's Avatar
joescvette
Default Headlight question????
I ordered the bushings for my headlights, but in the meantime I need to drive the car at night. Is there a way to keep the headlights up? The motor just keeps running. This is for a 88.
Old May 20, 2009 | 07:05 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
There are **** that can be turned on each light to rolate mechanism in the on position. It takes a bit of turning the *** to reach the on position, but it will work. Once in the on position turn light switch on to light up headlights.
SAVE THE WAVE
Old May 20, 2009 | 08:43 PM
tim32920's Avatar
tim32920
you can turn them on and then unplug the motor or unplug the motor than manually turn the **** till its sticking up.
Old May 20, 2009 | 09:16 PM
joescvette's Avatar
joescvette
Thanks I'll try that.
To Headlight question????
