Engine Cleaning Help
Old Jun 4, 2009 | 04:54 AM
olcrusty's Avatar
olcrusty
Default Engine Cleaning Help
Hey Men,
How the heck do you clean up the alternator casing and other aluminum parts that have gotten dulled and dirty for a car show? Mines a '96 LT4 with Opti and I refuse to spray and run water. So what the heck can I use? Any reasonable advise will be appreciated. Thank you in advance.
Al
Old Jun 4, 2009 | 08:06 AM
RedVette84's Avatar
RedVette84
I've been having alot of luck with scotch brite. There are several different abrasive levels - from extremely coarse to one that is fairly light. I use the light abrasive pad for the AC tubes and go to a medium pad for alternator. It's great for getting into dimply finish of the alternator. I tried never dull and some other metal polishes but they tend to leave a residue that you can see.
Old Jun 4, 2009 | 08:39 AM
engle1147's Avatar
engle1147
A small brass bristled (semi-soft) brush works well also....light strokes.
Old Jun 4, 2009 | 09:20 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
My motor needs a sand blaster seriously. I have tried over the counter stuff from NAPA and it's all overpriced crap IMO. Did not help mine...Others may have had better luck with Engine Brite, mothers aluminum polish ect but not me.
Old Jun 4, 2009 | 09:43 AM
ThomasRetUSN's Avatar
ThomasRetUSN
This is what I have done on my 86 Coupe. I use quad zero steel wool, scotch bright and Mother's Alum & Mag polish plus a lot of work but in the end it will pay off.
Old Jun 4, 2009 | 10:07 AM
pianoguy's Avatar
pianoguy
Beeyootiful work, man!
Old Jun 4, 2009 | 10:13 AM
olcrusty's Avatar
olcrusty
Default Thanks for all the suggestions
Hey ThomasRetUSN, you Navy guys always are spiffy.
Old Jun 4, 2009 | 10:29 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Hey Thomas, you are supposed to drive that thing.................
I use a small stainless steel brush. You can use the brush to "tap" it at the areas that have a rough surface, and slide the brush on areas that have a smooth surface. Just do not use heavy pressure as patience will pay off with light strokes and gentle tapping. Scotch bright is plastic sand paper, so be careful where you use it. If you use it on painted surfaces, you have just prepped the part for paint. also do not use it on chrome surfaces...... not that a corvette has any, but if you use it on your tail pipes, you will never get the scratches out.
Old Jun 4, 2009 | 10:51 AM
HlhnEast's Avatar
HlhnEast
Again, Thomas, great work! Youve got some serious time in it and it paid off!
Old Jun 4, 2009 | 01:02 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
That is one looking engine bay, nice job.
Old Jun 4, 2009 | 01:09 PM
Demonic85's Avatar
Demonic85
simple green and an old toothbrush. serious.
Old Jun 4, 2009 | 06:38 PM
RedVette84's Avatar
RedVette84
That's a beautiful job on that engine compartment!!!
Old Jun 4, 2009 | 06:56 PM
Motsiv2's Avatar
Motsiv2
Simple green, scotch brite, steel wool pad(like sos without soap), and a frickin back ache!
Old Jun 4, 2009 | 09:29 PM
larry00's Avatar
larry00
Thomas what do you use on the black plastic ?
Most stuff doesn't last very long !
Old Jun 4, 2009 | 10:40 PM
Elrick's Avatar
Elrick
sick man, just sick, awesome
Old Jun 4, 2009 | 10:51 PM
lostnfoundC4's Avatar
lostnfoundC4
Thomas, that does look nice-not overly done.
BTW, are they stock wheels? I don't recognize the tire tread with anything available for our year.
Old Jun 4, 2009 | 11:21 PM
CopperCorvette's Avatar
CopperCorvette
I can't recommend this product enough Copper
To Engine Cleaning Help
Old Jun 5, 2009 | 12:20 AM
CStewTAMU's Avatar
CStewTAMU
What I have found works great on black plastic is the turtle wax ice car wax. It makes the plastic look new, not greasy or wet like CD2 can.
That CD2 stuff will hide dirt on a dusty engine, but it won't be a clean "dry" look. It's basically an Armour All for engine bays.
Old Jun 5, 2009 | 12:45 AM
CopperCorvette
How long would it take to clean it up... your way or mine? Nuff said.
Copper
Old Jun 5, 2009 | 12:53 AM
CopperCorvette
Here are a couple of before and after pics.
Let the members give or
