Jerking Corvette
Old Jun 7, 2009 | 11:21 PM
miscstudent's Avatar
miscstudent
Default Jerking Corvette
Hey all,
Well, just got back from a 200 mile drive this afternoon, decided to pick up a few groceries and BAM, out of the blue, as I'm pulling out of the lot (from a stop) my Corvette starts jerking. The rest of the drive home (2 miles) was awful, and on that drive my car felt like it wasn't selecting gears properly. I should add that it is a 1990 with 156,000 miles in an automatic. It is stock. I assume that it is probably the transmission failing since it felt a lot like it was trying to engage 1st gear.
Also, since I bought this car I have had a lot of trouble trying to get it into reverse and the overdrive selection.
What do you think? Sound like the transmission? Will it need to be rebuilt? Could it be the differential/universal? Can I do this work on my own using the factory service manual from Helms?
Thanks!
Old Jun 7, 2009 | 11:59 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Sounds like a transmission problem for sure. Not an easy fix even with a manual. Pull it out and have it rebuilt.
Old Jun 8, 2009 | 07:52 AM
RedVette84's Avatar
RedVette84
Sounds like a trans. I'd have good trans shop work on it though.
Old Jun 8, 2009 | 09:15 AM
miscstudent
Darn. I figured that it was the transmission. :-\ Anyone recommend a shop near Thousand Oaks, Ca or Ventura County, Ca? I'll make some calls today about it. While I'm having it rebuilt, any recommendations on high performance parts? I might as well I suppose.
Old Jun 8, 2009 | 09:41 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like a bad set of plug wires or a cracked dist. cap or the plugs finally gave out or the egr valve stuck partially open.
Also, the gear selection may be a bad shifter cable. Thr jerking in and out may also be low trans fluid or a dirty trans filter. lots of possibilities. Get with a friend that messes with cars and see if he may have some suggestions.
This doesn't sound bad just yet.
Old Jun 8, 2009 | 10:57 AM
65747785's Avatar
65747785
Check the plugs, wires, cap and rotor first.
Old Jun 8, 2009 | 03:09 PM
pologreen1's Avatar
pologreen1
trans or torque converter, is it only happening in overdrive ?
PETE K the expert will help you
bump
Old Jun 8, 2009 | 05:25 PM
miscstudent
bump
Haha thanks for the bump
I am not sure. When I was driving it, it was in overdrive (how I always drive it) but I will try it in regular drive and post how that goes on here.
Old Jun 8, 2009 | 05:29 PM
miscstudent
I thought about the fluid levels but it looked ok (I last checked right after I got home so it was still hot. I'm going to check it again this evening now that its had time to cool off). I will try to check the plug wires and distributor cap tonight. Any tips on checking the EGR valve, plugs, and filter?
Old Jun 9, 2009 | 12:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you getting any codes? Service Engine Soon lamp come on?
Checking for bad wires is simple. Just open the hood at night or in a darkened garage, start the engine and remove the hood lamp fuse. Look closely at the coil and spark plug wires for arcing, electrical creepy crawlies, etc...
If you see 'em, you've got bad wires. If the wires are suspect, odds are it's time to do the plugs, too, especially if you know for a fact they haven't been changed recently.
Old Jun 11, 2009 | 12:12 AM
miscstudent
Well I sure feel like a goof. Went down to the local autoparts store, bought some new transmission fluid, poured it in and it started right up with no problems. :o
I am going to take it to a shop now to get its fluid changed, new filter and re-sealed but I wanted to thank you all for your responses. I do feel silly lol. At least i'm back to happy-corvetting
Old Jun 11, 2009 | 12:21 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
So how low was the fluid level?
Did ya have to pour in three quarts?
Old Jun 11, 2009 | 12:24 AM
coupeguy2001
just as a side note,
1. check trans fluid hot.
2. check all the other stuff we told you to prevent you from having another "hiccup"
Old Jun 11, 2009 | 12:30 AM
miscstudent
Surprisingly it wasn't that low. I only put in about half a quart and its running great now- no problems. I ended up driving it around with no issues. Of course, its an automatic and as much as I can tell they freak out the second fluid gets too low or too high.
Definitely will do. Just wanted to share for now about how much of a goof I felt like for freaking out like that. : )
Old Jun 11, 2009 | 10:21 AM
RedVette84's Avatar
RedVette84
Be careful if you get the trans power flushed. Had two transmissions flushed and within weeks both died.
Old Jun 11, 2009 | 10:59 AM
Pwnage1337's Avatar
Pwnage1337
did the shops pay for the transmissions after they were ruined? My dad just had the transmission on his van flushed and I'm worried its going to fail, because he will take it to the shop and hit them with cro-bar.
Old Jun 11, 2009 | 11:08 AM
JrRifleCoach
That trans is to old too mess with. Run the current fluid and keep it topped off.
Save your money and then have it rebuilt.
If you change your fluid, it will be a crap shoot!
To Jerking Corvette
