AC Question/issues
Old Jul 15, 2009 | 07:29 PM
bpdfs's Avatar
bpdfs
Default AC Question/issues
1993 40th.
AC seems to work when its on auto.. if I put it on to just blow front face vents it sometimes will work and sometimes wont and when it works its cold for the first few seconds and then goes warmer??? Any ideas?? any help???
Old Jul 15, 2009 | 07:40 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Originally Posted by bpdfs
1993 40th.
sounds like you need a recharge
Old Jul 15, 2009 | 08:10 PM
Red Dwarf's Avatar
Red Dwarf
Isn't front face the vent position? I can't remember?
Old Jul 15, 2009 | 08:47 PM
jtc44's Avatar
jtc44
Default A C Prob
No vette expert am I bu all AC probs. need to start out with pres. check A good set of gages and a good understanding of ac basicks! Do not charge if not needed check all other HVAC modes Is comp. running all the time ac is called for And a fact SM is tops on my list!! But what do I know I own an 84 vette and I work on Honda cars
Old Jul 15, 2009 | 09:45 PM
Wathen1955's Avatar
Wathen1955
You have the automatic temperature control. If you select vent all you get is outside air and the AC is turned off. I had the same problem when I bought my 96. I pressed the vent button and expected AC but all I got was warm air.
My 96 manual says:
Manual Cooling
The air conditioner works best if you keep your windows closed. On very hot days, open the windows just long enough for the hot air to escape. Press the arrows on the TEMP ,SET switch to set a comfortable temperature. Press RECRCULATE. After cool-down, adjust the airflow to another setting. The compressor works in all settings except VENT and HEATER, and at all temperatures above freezing. Press the arrows on the fan’ speed switch if you don’t like the automatic setting. In AUTO FAN on hot days,the fan speed will be low at first to help get rid of the hot inside air. When the air conditioner is on, you may notice slight changes in your vehicle’s engine speed and power. This normal because the system is designed to cycle the compressor on and off to keep the desired temperature and help fuel economy.
To AC Question/issues
