Wiring
Old Oct 24, 2009 | 09:58 PM
marine69's Avatar
marine69
Cruising
Default Wiring
Can anbody tell me what is worse on a 1986, ignition switch, vats, or starter relays. I have no fire at the solenoid?
Old Oct 25, 2009 | 10:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would have to say "ignition switch", the other 2 are easier to access.
Check for power at the starter enable relay, during crank. That should help narrow it down.
Did you try another key, or clean the pellet on existing key ?
Here's info on 86 VATS
http://members.shaw.ca/dankai/Vats%20Electrical.pdf
The clutch switch or gear selector switch, can also be added to the mix.
Here's 86 starter circuit
http://members.shaw.ca/agent86/Start...g%20System.pdf
Old Oct 25, 2009 | 03:48 PM
kelly1's Avatar
kelly1
Thanks a ton. Will work on it.
To Wiring
