Oil
Old Nov 30, 2009 | 10:26 AM
hln111's Avatar
hln111
Default Oil
The question is: 1985 corvette with 109,000 mi. What weight oil is recommended for normal spring to fall driving in Michigan?
85 Gold
Old Nov 30, 2009 | 10:54 AM
glass slipper's Avatar
glass slipper
0W30, oil is like a religion so you'll have all kinds of opinions as to which brand is the best. Having said that, I use Mobil 1 but any of them will work just fine, even the Walmart/auto parts store brand. GM specified 5W30 for your car when it was new and even with 109K miles on it, there is no need to go to an xW40 oil. My daily driver has almost 200K miles on it and I use 5W30 with fantastic oil pressure hot and cold.
Old Nov 30, 2009 | 11:43 AM
WW7's Avatar
WW7
5w-30w or 10w-30w is what my book calls for, the only time to use anything higher is if you have a oil pressure problem near the motors end of life, or speciel racing needs...WW
Old Nov 30, 2009 | 04:38 PM
RedVette84's Avatar
RedVette84
Stay with what the book says.
Old Nov 30, 2009 | 05:08 PM
hln111's Avatar
hln111
Thanks guy's for the advice, it's appreciated.
85 Gold
Old Nov 30, 2009 | 05:38 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I always use 10W30 Mobil 1 on both Vettes and my DD.
Old Nov 30, 2009 | 07:38 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Nov 30, 2009 | 10:26 PM
tblt44's Avatar
tblt44
10w - 30
Old Dec 5, 2009 | 01:32 AM
shadowmoon's Avatar
shadowmoon
2nd Gear
My '85 I use 10-30wt.castrol synthetic.
Old Dec 5, 2009 | 11:15 AM
c4cruiser's Avatar
c4cruiser
C4's use a 5W-30 oil as the recommended grade. Even with over 100K miles on the car, stay with the 5W30.
The owner's manual shows a temperature range for the 5W-30 is from -20 F to over 100 F. 10W-30 should not be used at temps below 0 F.
Old Dec 5, 2009 | 11:30 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Dec 5, 2009 | 01:17 PM
Wathen1955's Avatar
Wathen1955
Yeah but if you live in a climate where it never drops below 32°F, but goes close or over 110°F, then I use 10-30.
Most vehicle manufacturers today specify 5W-20 or 5W-30 for newer vehicles for year-round driving. Some European car makes also specify 0W-20, 0W-30, 0W-40 or 5W-40 for their vehicles. Always refer to the vehicle owners manual for specific oil viscosity recommendations, or markings on the oil filler cap or dipstick.
As a rule, overhead cam (OHC) engines typically require thinner oils such as 5W-30 or 5W-20 to speed lubrication of the overhead cam(s) and valve-train when the engine is first started. Pushrod engines, by comparison, typically specify 5W-30, 10W-30 or 10W-40.
As mileage adds up and internal engine wear increases bearing clearances, it may be wise to switch to a slightly higher viscosity rating to prolong engine life, reduce noise and oil consumption. For example, if an engine originally factory-filled with 5W-30 now has 90,000 miles on it, switching to a 10W-30 oil may provide better lubrication and protection. The thicker oil will maintain the strength of the oil film in the bearings better so the engine will have more oil pressure. This will also reduce engine noise and reduced bearing fatigue (which can lead to bearing failure in high mileage engines).
http://www.aa1car.com/library/oil_viscosity.htm
To Oil
