Replacement For LCD Dash 84-89
Old Dec 17, 2009 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Replacement For LCD Dash 84-89
I got an Email from Corvette America, about their new product. Just thought I would post it for those looking to replace the Star Wars dash.
http://www.corvetteamerica.com/cf/di...510&Rcp=134943
Old Dec 17, 2009 | 03:33 PM
RedVette84's Avatar
RedVette84
That's different and not bad looking. Great for someone who wants to get rid of the digital.
Old Dec 17, 2009 | 03:38 PM
Relic's Avatar
Relic
Wow, pretty expensive. I guess you'd have to really hate your digital dash?
I've seen analog replacements before, but none mass marketed. This one isn't as nice as the the others, but it's not hideous.
Old Dec 17, 2009 | 04:48 PM
2UHONEY's Avatar
2UHONEY
Same dash as my 64 truck.that's going backwards it's like removing your GPS and replacing it with a compass.I'm a person that's always modernizing, if I can find a Heads up and fully digital dash retrofit for my 92 that I'll be interested in.
Old Dec 17, 2009 | 05:10 PM
WW7's Avatar
WW7
You would lose a lot of dash functions.. MPG, Miles traveled, instant fuel rate, Range....WW
Old Dec 17, 2009 | 05:36 PM
JackDidley's Avatar
JackDidley
Not bad but I liked the one Vinnies87 made better. I actually like my starwars dash so I'm keeping it.
Old Dec 17, 2009 | 06:14 PM
ps374's Avatar
ps374
Why would anyone what to do that????
Old Dec 17, 2009 | 07:26 PM
Brett Richmond's Avatar
Brett Richmond
I actually like it, I would be inclined to put it in a 2nd corvette if I ever get one, I like that Atari dash we have but would love to have one like this.
Old Dec 17, 2009 | 08:48 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
My digital dash works perfectly and I like it. I think I will use the $800 for useful upgrades.
Old Dec 17, 2009 | 09:44 PM
Brett Richmond
Wonder if it is truly a plug and play with the factory harness, if so I would really be interested cause you can just swap them out when you want if there are no wires to be cut?
Old Dec 17, 2009 | 10:09 PM
impact1968's Avatar
impact1968
I like the night rider dash too, just wish the speed was in the center and not off to the side.
Anybody got a rough ballpark on what the gauges cost by themselves for the analog setup?
Old Dec 18, 2009 | 04:31 PM
Brett Richmond
I called and talked to them about these being plug and go. The only thing you need to do is move the odometer over to the new set-up.
Old Dec 18, 2009 | 05:01 PM
pologreen1's Avatar
pologreen1
I think my 90' will see some thing like that if I keep it.
I think someone in the vette community makes them, might be cheaper than this one.
Old Dec 18, 2009 | 05:35 PM
sfc rick's Avatar
sfc rick
I agree with the majority too. I like my instrument cluster as it came from the factory. It's easy to repair and not that costly afterall....yet.
I learned that the cluster is kinda cool, and I liked doing the LCD replacements myself.
Old Dec 18, 2009 | 06:11 PM
redrose's Avatar
redrose
after engine mods,engine revs faster, and if tpi is upgraded the engine speed change does not slow as redline approaches... tach in the atari dash is useless/dangerous (clutch explo ?), segments of numbers are just a blur as they reset...use less loud pedal and watch close, atari tach continues upward when you let off
anyone know where automter gauges are now made ???...fwiw, firebird gauges which can be used in vette with no sensor changes were made in japan
Old Dec 18, 2009 | 06:14 PM
Aardwolf's Avatar
Aardwolf
Those came out about a year ago. Here is the manufacturer's page:
http://www.vettaid.com/default.aspx?cid=W5lW9TcdoWA=
Old Dec 18, 2009 | 08:37 PM
Mike263's Avatar
Mike263
Yeah, I'm looking into a gauge replacemet. A set of VDO "Vision" gauges (including oil pressure, oil temp, and water temp sensors) is right at $400.
Autometer gauges are about $430 - $450. You apparently also need a "4 out buffer assembly" to bridge the VSS to the ECM and speedo (if you have the 165 ECM). The buffer is a GM part out of a 87-89 firebird. Then, if you don't want to cut wires, you need the socket out of an old digi cluster or an old ECM and some soldering skils...
Oh and then you need an aluminum panel with holes cut to mount the gauges. Do a search on "analog gauges" and you can read the adventures of others.
I'm trynig a cheaper alternative - the cluster out of a 92 Camaro if I can figure out how to mount it in our dash. But if this doesn't work, I go for the after market gauges. Now I just need to find the connector and pig tail for the buffer assembly. Off to Pick A Part.
To Replacement For LCD Dash 84-89
Old Dec 18, 2009 | 10:12 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Sorry to say, it's not my taste. I like what I got, and it works and looks great!
Old Dec 19, 2009 | 03:58 AM
mazdaverx7's Avatar
mazdaverx7
i love my LCD cluster... when its working. i'll repair it and keep it original.
Old Dec 19, 2009 | 04:08 AM
85vette-84vette's Avatar
85vette-84vette
star wars rules. keepin the dash.
