Maintenance Reminder
Old Feb 1, 2010 | 03:57 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Default Maintenance Reminder
This weekend while messing with the vette I sprayed some WD 40 in the Clam Shell locking mechanism. It was starting to get a little tough to pull.
It is now openly freely and easily so don't find out the hard way you forgot to do this.
i have read many a thread of those whose cable snapped and this is an easy maintenance to help ward off any future problem.
Old Feb 1, 2010 | 05:15 PM
Wayne Pennell's Avatar
Wayne Pennell
Inside the car?
Old Feb 1, 2010 | 05:24 PM
RetiredSFC 97
Originally Posted by Wayne Pennell
Inside the car?
The engine bay where the hood latches and locks. They are up at the far end of the bay on the winshield side. I'm at work or I would snap a picture. They are the female locks where the male pin goes down through.
Old Feb 1, 2010 | 05:35 PM
olcrusty's Avatar
olcrusty
Olcrusty
Old Feb 1, 2010 | 05:40 PM
1st87's Avatar
1st87
kudo's to you-going to do that right now. thx
Old Feb 1, 2010 | 06:23 PM
pologreen1's Avatar
pologreen1
If you were you get some assisted shocks on it
Old Feb 1, 2010 | 07:15 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Old Feb 1, 2010 | 09:04 PM
Chuck Tribolet's Avatar
Chuck Tribolet
WD-40? Gaaack! It was designed as a water displacement fluid (that's
what the WD stands for). It's a mediocre lubricant (esp after it dries up)
and nowhere near as good on rusty bolts as stuff that's made for rusty
bolts (I have a salt-water boat trailer that gets dunked 140 times a year,
I have a deep relationship with rusty bolts).
'87 Factory Service Manual specs engine oil on the pivots and spring anchor,
and "Chassis grease meeting requirements of GM-6031M (GM Part. No.
1052497)" on the release pawl.
That said, it's a good idea to lube it, and you've reminded me I should
lube mine as it's gotten a bit stiffer lately.
Old Feb 1, 2010 | 09:47 PM
RedVette84's Avatar
RedVette84
Old Feb 1, 2010 | 10:15 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
But you still have installed the back up pull ties or wire realease system for the mechanism, right? Routine maintenance ..... good.
Old Feb 1, 2010 | 11:42 PM
jfb's Avatar
jfb
WD40 goes away in about a month. Spray some lubricating OIL on your hinge parts, NOT WD40!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 1, 2010 | 11:50 PM
Frizlefrak's Avatar
Frizlefrak
The DuPont Teflon lube is good stuff too. Use it on motorcycle chains as well. Same stuff as Chain Wax at about 1/3 the price....they have it at Lowes.
Old Feb 2, 2010 | 12:40 AM
pologreen1's Avatar
pologreen1
I use spit, just like on everything else.
Old Feb 2, 2010 | 12:44 AM
Pwnage1337's Avatar
Pwnage1337
i find this method very effective. i found out that i need to consume large amounts of water to keep everything in my house & cars nice and smooth
Old Feb 2, 2010 | 12:53 AM
pologreen1's Avatar
pologreen1
Old Feb 2, 2010 | 01:14 AM
carguy604's Avatar
carguy604
He's right on all counts. White Lithium grease works well in this application and is often available in a spray format.
Old Feb 2, 2010 | 02:08 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I do have the backup cable though.
The Ventura Star Automobile section recommended spraying on WD40 to make your convertible top look good. The Democratic Republic of California will not let us buy top protectant locally. It is deemed hazardous, so the only way we can get it is through mail order.
Anyway, that is what they told me at the different auto stores I went to.
To Maintenance Reminder
Old Feb 2, 2010 | 08:47 AM
Flame Red's Avatar
Flame Red
+1 - that stuff is amazing!
Old Feb 2, 2010 | 09:20 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Just did my drivers side this morning before work. Unbolted the latch, cleaned, then applied lithium grease to the spring and pivot point. She's nice and happy now. Also drilled a hole to let the stinking water drain. Tomorrow morning...the passenger side.
Old Feb 2, 2010 | 09:24 AM
olcrusty's Avatar
olcrusty
Right on with the lithium grease. I use the spray can with a rag around the area to be greased.
Olcrusty
