Help! My C4 doesn't go.
Old Feb 24, 2010 | 03:00 AM
vettecollector's Avatar
vettecollector
Default Help! My C4 doesn't go.
I have a 93. I was driving down the road and suddenly the car was slowing down.
As I step on the gas it doesn't go faster.
Leaving a dead stop I can feather the pedal up to about 20MPH after a long distance.
What is wrong?
Help is appreciated.
Old Feb 24, 2010 | 07:01 AM
aboatguy's Avatar
aboatguy
Hard to give a sound diagnosis with the limited info provided but it looks like your post has sat for a few howevers so I'll make a stab at a diagnosis and give you a bump.
I had a cat go bad on my 02 impala and it would run/idle fine but made no power...ie feather throttle and I could nurse it up to speed. So withthe info provided I'd lean towards cats.
With the limited info it could be a lot of things. So I'm shooting in the dark and I'd start with the easy things..look at the engine bay for obvious problems (ie: burned ignition wires, loose connections, discolored fluids etc)....pull codes (sometimes codes are stored without a check engine light....check fuel pressure if it looks good sitting in park....check it under load (tape gauge to windsheild and see what its really doing), check for spark at each cylinder, check catalyt converters,
Old Feb 24, 2010 | 07:26 AM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
I had some plug wires melt on me that created that problem. Check your wires.
Old Feb 24, 2010 | 08:51 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
excellent starting point,
Old Feb 24, 2010 | 09:23 AM
aminnich's Avatar
aminnich
The symptoms are typical of a clogged fuel filter. Any history on the maintenace of the car?
Old Feb 24, 2010 | 11:15 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old Feb 24, 2010 | 11:18 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
mine did something like that ,was icm
Old Feb 24, 2010 | 11:43 AM
vettecollector
Both computers were rebuilt about a year and a half ago.
Ran perfect since then. Ran perfect when I left the house until I was about 3 miles away. It wasn't gradual, it happened right away. I'll check a few things listed.....Thanks I guess I'll have to take it in.
Old Feb 24, 2010 | 12:03 PM
Loby 1's Avatar
Loby 1
Good luck with it and let us know what you find out.
Old Feb 24, 2010 | 12:21 PM
Frizlefrak's Avatar
Frizlefrak
I'll spare everyone my "they need 3 things to run" speech....
Let's get to troubleshooting. Start with the fuel system. Check your fuel pressure at the rail and tell me what you have. Hook up gauge, key on but don't start, tell me the guage reading and how long pressure holds after 2 second prime.
We'll go from there.
Old Feb 24, 2010 | 12:47 PM
ch@0s's Avatar
ch@0s
had the same problem .. could be the cat
Old Feb 24, 2010 | 01:55 PM
Tommy T-Bone
I agree with you but first I look for the obvious and easy then
Old Feb 24, 2010 | 01:56 PM
ch@0s's Avatar
ch@0s
yup can you say "flow chart"
Old Feb 24, 2010 | 02:00 PM
Frizlefrak's Avatar
Frizlefrak
Flow this
Yes.....look for anything obvious first. Barring a medusa of gelatinous spark plug wire goo, start troubleshooting.
Damn Texans
Old Feb 24, 2010 | 03:00 PM
pcolt94's Avatar
pcolt94
for a starting point.
Seems like this would be a nice easy solution.
A clogged filer might have good fuel pressure at idle, but have no flow at speed and load. But usually they exhibit symptoms gradually at the higher speeds where flow is greater, like 70 mph.
ICM would likely kill the engine complete and not make it slow down.
Even a melted plug wire is not going to slow down that V8 where you could not get up to 20 mph. Even 2 or 3 melted wires (by coincidence) it will probably keep going but shake a lot.
Knowing the FP would be nice.
I would think cats would be a gradual thing also and not happen suddenly.
I would check the TPS voltage.
Hope it's not the ECM.
IMO – Shot in the dark also.
Old Feb 24, 2010 | 03:21 PM
vettecollector
It starts just like a new car. When you have someone press on the gas pedal there is very little coming out of the exhaust pipes.
Sound like sensors or the cat?
NO CHECK ENGINE LIGHT EITHER.
Old Feb 24, 2010 | 03:28 PM
engle1147's Avatar
engle1147
If the exaust is blocked then the engine coolant temps should jump way up pretty quick....maybe check the cluster temp gauge.
My guess is that you have a weak "spark" or a fuel delivery problem...get a fuel pressure gauge and do some checking.
To Help! My C4 doesn't go.
Old Feb 24, 2010 | 06:49 PM
RC000E's Avatar
RC000E
I can't believe the **** flying around in the wind in here. There is NOT enough info to even remotely give even a semi accurate diagnosis.
You have to be MUCH more specific with symptoms, sounds, engine lights, idle quality, and anything else you can think of.
I guess I'll throw in my diagnosis based on the info...maybe all your tires are flat or your foot feels like its pushing but its really not.
EDIT: Didn't see you added some info. Still too vague in my opinion. Your going to have to do some basic troubleshooting like advised above. With something like this START SIMPLE. With no engine lights and the fact the car is running it points to fuel delivery, I'd start there.
Old Feb 24, 2010 | 06:58 PM
RetiredSFC 97
I believe aboatguy covered that!
Old Feb 24, 2010 | 10:27 PM
vettecollector
LISTEN RCOOOE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
There is no room for people like you on this forum.
I have a problem with my car, I am asking the kind people of the Forum to help me.
I mentioned the symptoms, I mentioned the NO ENGINE LIGHT among other things.
Its a shame that not all of us use this Forum to help each other out if we can. Go play your computer games somewhere else.
Your opinion is not needed, wanted or will be replied to again, thank-you to those who have put an effort in to helping me.
