Sanity check
I am looking at a tune up, so that is plugs and wires. I plan on picking up AC Delco OEM replacements. Should I just go ahead and replace the cap, rotor and coil since I am at it?
I will also be replacing all of the fluids:
Oil
Transmission (Auto)
Coolant
Brake fluid
Am I missing anything?
Plug wires, no need to go AC Delco unless you are trying to keep it stock looking. I use MSD wires.
Air filter...check it.
Fuel filter. I change mine every 10,000. Located on passenger side (inside frame rail) behind front tire.
To change coolant, drain radiator, pull knock sensor on passenger side (in front of starter) it has a shield over it. And also unscrew the pipe plug in the block on the drivers side. This will drain the entire block and radiator. When you take out the knock sensor, it may not drain due to rust build up inside the block. Take a screwdriver and insert it in the hole.....coolant will come out FAST...so be prepared.
Oil
Transmission (Auto)
Coolant
Brake fluid
It has 75,000 miles, it has not had many at all the last few years.
Distributor terminal board? I am not familiar with that and Rock Auto doesn't list it, not that I could see. Is that the cap/cover?
I found a set of Delco wires for $21, so that seems a good buy. That and I do like the stock look.
I already changed the air filter, it was bad.
Thank you for the advice on the fuel filter, I will add that to the list.
Does anyone have an opinion on Standard Motor Products ignition parts?
Standard Motor Products are OK for many cars, but for things like a distributor cap and rotor, go with MSD. The cap and rotor uses brass terminals and will last longer than the regular aluminum terminals. When buying the cap, make sure you get the proper style. Some C4 distributors will have the spring-loaded clamps and others will use the screw-down clamps.
When you install the wires, use some dielectric grease on the spark plug boots and the coil ends. That will keep moisture out. Make sure the Delco wires are the correct ones for a Corvette and not just a SBC motor; the #6 plug wire should have a 135 degree boot for the spark plug.
Even though the car doesn't have a lot of miles, if the radiator hoses are OEM, replace them. Hoses can get weak on the inside and if the lower hose collapses, it will cut off coolant flow. May not hurt to get a new thermostat too.
How does the PS fluid look? Dirty? You can change that using the "turkey baster method". Get a $2 baster at the local grocery store. Use it to suck all of the PS fluid out of the reservoir and refill with fresh fluid . Drive it around the block a couple times and repeat. Do this 5 or 6 times to get the old fluid out. You don't need anything special for PS fluid, just something like Valvoline PS fluid or similar. Synthetic fluid is OK too.
