Acceration problem
Old Dec 11, 2010 | 02:57 PM
jabez's Avatar
jabez
Default Acceration problem
I seem to lose the ability to accelerate on my 92 auto.
In town driving around 30-35 mph the car drives fine. When I hit the Highways I floor it and the car starts to tremble ,shake,surge back and forth.
Need suggestions and ideas.
Old Dec 11, 2010 | 03:17 PM
sailorsteve's Avatar
sailorsteve
Some ideas:
Replace the fuel filter.
Check the cats. With the car warmed up and idling, CAREFULLY check to see if the pipe temps seem roughly equal upstream and downstream of the cats. If hotter upstream, cats are partly plugged.
How many miles on plugs, wires, etc. Is it time for a tuneup?
How clean is the air filter?
Pull codes to see if there are emissions systems issues.
Old Dec 11, 2010 | 05:51 PM
rithsleeper's Avatar
rithsleeper
easy fix... cut exhaust after manifolds, remove excess. Then replace manifold and up with carb setup. Might sacrifice fuel economy but everyone would look at you and think, man that guy gets it. He is so awesome.
seriously though, I agree with sailorsteve, he hit the nail for all my past problems/ experiences. Fuel filter has been the culprit a few times
Old Dec 11, 2010 | 10:26 PM
jabez's Avatar
jabez
Originally Posted by sailorsteve
Some ideas:
Well I get no codes and fuel filter and air filter was replace within the last month. Plugs and wires were changed about 5-6 years ago. Maybe I will check into those.
Old Dec 14, 2010 | 07:11 PM
jabez's Avatar
jabez
Replacing the Plugs and wires did the trick! Thanks guys. Everything in the universe is fine again.
Old Dec 14, 2010 | 08:13 PM
F40's Avatar
F40
I was thinking fuel problem
Old Dec 14, 2010 | 08:14 PM
pcolt94's Avatar
pcolt94
Congratulations, you must live right. If those symptoms were mine, it would be an opti.
Old Dec 14, 2010 | 09:51 PM
F40's Avatar
F40
Forgot about the opti spark
Old Dec 17, 2010 | 12:37 AM
jabez's Avatar
jabez
Well my Opti crap out on me 3 years ago and I replaced it with an MSD.
To Acceration problem
