Over COOLING problem
Old Jan 26, 2011 | 01:15 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
This sounds like not enough water flowing past the coolant sensor.
1. Does the low coolant light come on at any time?
2. carry a jug of water and when the temp is low, pull off quickly, open the radiator cap, and refill the water with the idle elevated.
3. Could there have been a heater tube cap that got dislodged into the heater core and with the RPM up the water bypasses the heater core and with slower water flow, then it goes in the heater?
4. Is it possible that the radiator fans are going on when the car is in motion or in gear? roll the window down and listen.
5. THe thermostat could be a problem, but when mine stuck open, I had 150 degrees coasting, going down hill, and 179 degrees every other speed.
Old Jan 26, 2011 | 03:11 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Have you put the first thermostat and a thermometer in a pan of water on a stove and watched its operation as the water warms up? Does the thermostat close as the water cools off? Since the first thermostat apparently works the same as the second (which is very unlikely that both would be bad) that's at least some confirmation that it's not a thermostat problem.
Old Jan 26, 2011 | 07:57 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
sounds like air in the system to me.
Old Jan 26, 2011 | 08:52 AM
aklim's Avatar
aklim
After all he has driven, I would think it has burped out.
Old Jan 26, 2011 | 09:21 AM
Humfreeze's Avatar
Humfreeze
The problem remained the same after I changed the thermostat. However, I have noticed that even after driving the vehicle for many miles, When I stop and attempt to check the fluid levels, I can immediately take the radiator cap off without the usual build up of pressure and outpouring of fluid that occurrs when you try to take the cap off of any other vehicle without a cooling off period. It seems that there is no pressure in the system but there is no cooling fluid loss either. And Yes the FSM that I am using is the original that came with the vehicle. My thought on the purge valve that I earlier suggested came from a 1984-1992 Chiltons manual that I also have and it talks about purging air from the system in that manual. I also ensured that the water caps were reved prior to installation.
Old Jan 26, 2011 | 09:23 AM
usmc_butler's Avatar
usmc_butler
Im in sorry I have no answer to help you but, I want to know the outcome of this
Old Jan 26, 2011 | 09:45 AM
aminnich's Avatar
aminnich
There are no air bleed screws on the L98, that started with the LT1 with the reverse flow cooling.
Old Jan 26, 2011 | 09:56 AM
Larry/car's Avatar
Larry/car
Disconnect the fan wires. Make sure the heater is in the off position and drive the vehicle and monitor the coolant temperature. This should eliminate the fan and heater core. Let us know result.
Old Jan 26, 2011 | 12:26 PM
Humfreeze's Avatar
Humfreeze
OK I will try this tonight.
Freeze
Old Jan 26, 2011 | 01:04 PM
Larry/car's Avatar
Larry/car
Take some cardboard along , if the fan and heater core doesn't increase your coolant temperature, block off some of the radiator, not totally. This will tell if the new thermostat was defective (wouldn't be the first time a new part was bad). Monitor your oil temperature and check your engine for signs of overheating. Coolant in the radiator is pumped through the engine by the pump and returns to the radiator, flow control is temperature controlled by the thermostat, it's a simple system, we will solve this.
Old Jan 26, 2011 | 01:45 PM
pcmusicer's Avatar
pcmusicer
Cruising
Default Cooling problem
If you are sure that it is over cooling, and not just giving a bad reading at the gauge, you could have a flow problem allowing the coolant to spend too much time in the radiator, just as removing the thermostat will cause a over heating problem due to the coolant flowing too fast through the radiator and not spending enough time in it too cool down, to much time or slow flowing could cause an over cooling problem. also the fans running all the time could cause this problem.
Old Jan 26, 2011 | 02:07 PM
Larry/car's Avatar
Larry/car
Another thing to check; open the radiator cap and check the flow when the thermostat opens, you should notice the flow increase. If the flow is constant, even when the engine is cold, the thermostat is open and doesn't close (the thermostat fails open). These checks should isolate us down to either the fans are coming on when they shouldn't or the thermostat is not working properly. I can't think of anything else in the system that will not allow the engine to come up to normal operating temperature, I can think of lots of things that will make it run hot. You never told us if this car ran cool before the heater core change.
Old Jan 26, 2011 | 02:25 PM
  #33
Moon86's Avatar
Moon86
You really need to get an infrared thermometer from Harbor Freight. If you don't you'll be just guessing at the temps of the hoses, rad, and thermostat housing. They also have alot of other uses, such as, setting the hot water heater, checking for air leaks in winter around doors and windows, etc. They are well worth the $30.
Old Jan 26, 2011 | 02:42 PM
  #34
Larry/car's Avatar
Larry/car
I was thinking, yes scary; did you change the coolant? This is out of my expertise, the wrong coolant/chemistry could effect heat exchange and coolant flow.
Old Jan 28, 2011 | 11:59 AM
  #35
Humfreeze's Avatar
Humfreeze
I have been flying the last 2 days but now I am ready to re attack this problem. I am going to stop at Harbour frieght on the way home and pick up the tool to check the temps. The cooling fans are not running all the time and seem to be cycling on and off as necessary. I am going to change the coolant again this weekend and see what happens. Thanks for all the help with this. I will probably get this figured out right about the time it gets too warm to use the heater again.
Oh and just to confirm, the car has always ran at the correct temperatures until I changed the Heater Core.
Old Jan 28, 2011 | 02:35 PM
  #36
Larry/car's Avatar
Larry/car
Has to be something that changed/happened with the core replacement.
Old Jan 28, 2011 | 03:59 PM
  #37
Moon86's Avatar
Moon86
Once you can determine the actual temps of things under the hood you'll have a much better handle about what is going on. Those infrared thermometers are really handy. When I tow my camper I check the tires everytime I stop to see if any are building up too much heat.
To Over COOLING problem
Old Jan 28, 2011 | 04:20 PM
  #38
aklim's Avatar
aklim
Any chance there is some debris in the heater core? Maybe remove the hoses and backflush it to see if anything comes out.
Old Jan 28, 2011 | 05:19 PM
  #39
drmrman's Avatar
drmrman
Could reversing the heater core coolant lines cause this? Just a thought....
Old Jan 28, 2011 | 05:30 PM
  #40
aklim's Avatar
aklim
Don't think so. I believe he said the lines were different sized.
