Over COOLING problem
Old Feb 6, 2011 | 03:47 PM
  #101
ch@0s's Avatar
ch@0s
Originally Posted by Humfreeze
Update I took the thermostats back to Auto Zone and even though they are warranted, the Manager has refused to refund my money due to the fact that he does not believe that 2 thermostats can be bad. I am currently writing a letter to Corporate headquarters to try and resolve this issue. I have dealt with this particular AutoZone for years to the point that they even know my name when I walk through the door and since they have recently had a Management change, things have turned for the worse at this particular store.
Boil them to see if they are bad or not.
Old Feb 6, 2011 | 05:33 PM
  #102
jfb's Avatar
jfb
Take your pot of water, an electric heating element and a thermometer and prove to him that the thermostats open at the wrong temperature.
Old Feb 6, 2011 | 10:54 PM
  #103
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by jfb
Hot Rod Roy was the first to tell you to put the thermostat in a pan of water and heat the water.
Thanks, jfb. Sometimes it's necessary to go back to the basics, rather than assuming everything is working like it should!
Good write-up, Humfreeze!
Party Time!!
Old Feb 7, 2011 | 09:17 AM
  #104
Larry/car's Avatar
Larry/car
That was a good trouble shooting problem. You had me scratching my head, running out of ideas!! Now go out and have fun. - Larry
Old Feb 10, 2011 | 10:51 PM
  #105
pcolt94's Avatar
pcolt94
I had a comment but did not want to take the thread off in another direction before the problem got resolved.
I would have never thought you could get a C4 the that lower temperature when the stat is defective or opens early in this case. I guess the cold outside temperatures really did more affect than I thought it might of.
Here in Orlando it's mostly warm, 60s, or real hot in summer. Not many weeks of 30s type weather here thank goodness. We normally would not have the temperatures here to see that effect.
