Over COOLING problem
Old Feb 1, 2011 | 11:27 AM
  #61
Larry/car's Avatar
Larry/car
I revisited your previous info. When the car is sitting engine idling and the temperature is at 180 degrees advance the throttle to 2200 rpm and observe the temperatures. If they drop the increased coolant flow is opening/bypassing the thermostat. Let us know what you observe.
Old Feb 1, 2011 | 03:51 PM
  #62
Humfreeze's Avatar
Humfreeze
Ok
Here are the temperatures with the car idling until it is showing 190-200 degrees on the Temperature Gauge and Thermostat is definitely open and cooling fans operating/cycling as advertised:
Then I got into the car and drove home. 37 miles of interstate into my driveway. Here are the readings after pulling into drive way:
1. Top Radiator hose from Thermostat housing to Radiator 115 Degrees
2. Bottom Radiator hose--115 Degrees
3. From reservoir into Heater core 104 Degrees
4. Heater Core output with fan for blower motor running on high 77 Degrees while at highway speeds.
Thermostat housing 145 Degrees right after stopping in driveway.
5. Heat out of vents 97.5 Degrees with vehicle idling
Then I let the car idle in drive way for about 7 minutes and all the temps return to the previously stated temps.
Freeze
Old Feb 1, 2011 | 04:24 PM
  #63
Larry/car's Avatar
Larry/car
The top radiator hose is the inlet, the bottom is the radiator outlet. There is no drop in temperature from the inlet to the outlet. What's that telling us? The coolant is flowing so rapidly that no more heat can be extracted? It has gotta be getting past the thermostat with little or no resistance (the thermostat housing shows a slight increase in temperature). Put the OEM thermostat in it, make sure that the unit is tight in the recess and there is no way for coolant to bypass it.
Old Feb 1, 2011 | 04:27 PM
  #64
Humfreeze's Avatar
Humfreeze
Sounds right to me. I have ordered the new thermostat and will put it in tomorrow night.
Freeze
Old Feb 1, 2011 | 04:54 PM
  #65
anciano's Avatar
anciano
Do I understand that the fan(s) came on at 200 degrees? That ain't right.
Old Feb 2, 2011 | 12:13 AM
  #66
jfb's Avatar
jfb
Nope, very few CFers understand heat transfer. The faster you pass coolant through the engine/radiator, the faster you remove heat from the engine. That is how the thermostat controls the engine temperature, it opens and allows higher coolant flow rate which removes heat from the coolant at a faster rate. For the umpteenth time, within the capabilities of normal waterpumps, there is no such thing as coolant going so fast that heat isn't removed. Heat transfer is proportional to the difference temperature between the air passing through the radiator and the temperature of the coolant in the radiator.
The OP's problem of 100 degree coolant when driving is due to coolant flowing too fast which can happen if the thermostat is too far open or coolant is somehow bypassing the thermostat. Very high waterpump pressure (high flow waterpump) can force open a thermostat.
Old Feb 2, 2011 | 08:03 AM
  #67
anciano's Avatar
anciano
For the umpteenth time, within the capabilities of normal waterpumps, there is no such thing as coolant going so fast that heat isn't removed. The OP's problem of 100 degree coolant when driving is due to coolant flowing too fast which can happen if the thermostat is too far open or coolant is somehow bypassing the thermostat.
Am I the only one who sees a contradiction here?
Old Feb 2, 2011 | 08:21 AM
  #68
jfb's Avatar
jfb
Where is the contradiction? Posters in some of these cooling discussions claim that less cooling occurs if the coolant flow is high. The OP's problem is exactly that, he has 100 degree coolant BECAUSE his coolant flow is high causing excessive heat flow out of the engine.
Old Feb 2, 2011 | 09:11 AM
  #69
anciano's Avatar
anciano
All I have seen are references to excessive cooling when the thermostat is stuck in the OPEN position, indicating excessively free passage of coolant. Where did you get the idea someone said otherwise?
Old Feb 2, 2011 | 12:16 PM
  #70
jfb's Avatar
jfb
Right here from pcmusicer: RIF
If you are sure that it is over cooling, and not just giving a bad reading at the gauge, you could have a flow problem allowing the coolant to spend too much time in the radiator, just as removing the thermostat will cause a over heating problem due to the coolant flowing too fast through the radiator and not spending enough time in it too cool down, to much time or slow flowing could cause an over cooling problem. also the fans running all the time could cause this problem.
Old Feb 2, 2011 | 12:18 PM
  #71
powerpigz-51's Avatar
powerpigz-51
I think that we can all agree that if the coolant stopped flowing (closed stat), that the coolant would have no choice but to get "hot". I do not think there is any other way that the coolant could get by a closed thermostat into the radiator.
Old Feb 2, 2011 | 12:46 PM
  #72
anciano's Avatar
anciano
ONE comment on the second page of this lengthy discussion prompts you to snarkily complain that you have to explain something "for the umpteenth time?" Your imperial patience must be sorely tried. In any case, I believe your reference was to "posters" (plural) in "some of these discussions" (plural).
Chill out, bud. This ain't a seminar and you ain't the professor. The purpose of this discussion was to solve the OP's problem, not denigrate those with a different view.
Old Feb 2, 2011 | 01:05 PM
  #73
jfb's Avatar
jfb
Hmm.....I don't even know what doing anything snarkily means. You are just upset because I showed you where in this thread that someone did say you get insufficient cooling with excess coolant flow.
Also, you need to look up the meaning of denigrate because I most certainly didn't denigrate anyone over their different view.
Old Feb 2, 2011 | 01:56 PM
  #74
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You haven't been around this forum long enough to realize how often people do get this wrong.
jfb was pointing out a fact to clear a misconception, nothing more.
Facts are one thing we can never have enough of.
We get way too many "A friend told me" type stuff.
Old Feb 2, 2011 | 02:33 PM
  #75
Humfreeze's Avatar
Humfreeze
This all good but my car still has no heat!!!
But thanks for all the inputs.
Temp here today is around 70 degrees and I drove pout to lunch and car temps run around 140 degrees on the gauge on a warm day like today. I will let you know tomorrow since it is suppose to go back down to 30 degrees tonight.
FREEZE
Old Feb 2, 2011 | 02:53 PM
  #76
ch@0s's Avatar
ch@0s
He has an air pocket in the system .. The sensor is giving him a false reading because it takes the temp from the coolant. The Heat is not working because he has air in the system.
Burp the system
Old Feb 2, 2011 | 03:34 PM
  #77
jfb's Avatar
jfb
Burp the system
He doesn't have false coolant readings. He gets heat at idle and has normal coolant temps, then when he gets on the road, his coolant temp drops and he gets no heat out of his heater core.
He might have air in his cooling system though.
Humfreeze, turn your rad cap to its first stop, idle engine until the themostat opens, race engine slightly and remove the rad cap, if you have air in your cooling system you will see coolant flowing into the radiator but the coolant level will be out of sight. If so, then engine racing, pour coolant to the top of the rad filler neck, replace the rad cap and then let the engine back down to idle. Take a drive and see if your coolant temp then stays close to the opening temp of the thermostat. Sometimes you have to burp the cooling system more than once.
To Over COOLING problem
Old Feb 2, 2011 | 04:10 PM
  #78
ch@0s's Avatar
ch@0s
If there is an air pocket in the system you can get a false reading at times. Otherwise how do you figure a running engine at 100 degrees.
Old Feb 2, 2011 | 04:30 PM
  #79
Humfreeze's Avatar
Humfreeze
I took the vehicle to a well established corvette shop here and they drained and replaced the coolant system level. This is not a coolant air in the system problems. I amcertain there is no air in the system at all.
Old Feb 2, 2011 | 04:34 PM
  #80
ch@0s's Avatar
ch@0s
Then why don't you take it back to them.
I have seen it a thousand times it can and will happen. Do yourself a favor and burp it anyway.
I think you have an air pocket. Either that or you have more than one problem.
