Finally getting fixed
Old Jan 29, 2011 | 10:40 AM
Nitestalker's Avatar
Nitestalker
Default Finally getting fixed
Well looks like I will finally be fixing my bucket. I had the guys at school run a compression test, wet and dry. A leak-down test and vacuum test. 175 P.S.I on all cylinders and everything else looks good so I pray that when I get the heads done that my smoke issue will be gone. I'm going to put a mild cam, with new lifters, pushrods and timing set. Headers and 1.6 R/R's. I will still need the smog pump delete bracket but that will have to wait. We came to the conclusion that a bad guide in #5 has been my issue. On a side note. I'm only 852 miles away from 400k lol. Thanks Mike for the help with all my Pm's, your a classy guy.
Old Jan 29, 2011 | 10:59 AM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Don't forget new springs.....with RR's and a new cam, might as well replace them, they are cheap and if the original one's have almost 400K on them...just saying
Old Jan 29, 2011 | 11:03 AM
Nitestalker
I already did those a few months back. I was already planning on the cam back then. Thanks for noticing that I didn't put them on there.
To Finally getting fixed
