FM Radio Antenna Problem
Old 03-19-2011, 11:49 AM
karentice
karentice's Avatar
Default FM Radio Antenna Problem
Short background - Replaced antenna mast. Had to take motor out to remove broken parts. Now I only get AM radio. The radio scans but doesn't pick up any FM stations. Anyone know which wire I hooked up wrong? Really stumped here. Thanks, Karen
Old 03-19-2011, 12:09 PM
whitenow
whitenow's Avatar
Default the mast extends/retracts?
I am assuming that the mast is extending/retracting. The big fat black coaxial is the radio signal carrier. I have to ask if you cleaned the area where the mast touches it's housing, too. The last thing would be the external ground lead. What year are we dealing with?
Old 03-19-2011, 01:20 PM
karentice
karentice's Avatar
1990 Convertible. The mast is now going up and down perfectly. The radio sounds great on AM stations, but, I can't get any FM stations. Is there a particular wire which governs FM? If it were the ground, wouldn't it affect both AM and FM? You know, now that I think about it, we found the ground unhooked when we went to remove the motor. Now it's hooked up again.
Old 03-19-2011, 02:14 PM
Chuck Tribolet
Chuck Tribolet's Avatar
It's the same antenna cable for AM and FM. There's
nothing unique to FM in the antenna. I think
you have a radio problem, not an antenna problem.
Old 03-19-2011, 04:12 PM
karentice
karentice's Avatar
Dang!
Old 03-20-2011, 01:06 AM
trulytex
trulytex's Avatar
Did you have any problem receiving FM Stations before you repaired the antenna? I would suggest putting the ground wire back the way that you found it before you repaired the mast and see if that helps.
Old 03-20-2011, 08:50 AM
karentice
karentice's Avatar
The last time the antenna worked, the FM was fine. Maybe we'll give that a try. Thanks.
Old 03-20-2011, 07:02 PM
rob-cyn
rob-cyn's Avatar
My FM works but not that well, always sounds weak
Old 03-20-2011, 07:52 PM
karentice
karentice's Avatar
Mine's TOTALLY static.
To FM Radio Antenna Problem
Quick Reply: FM Radio Antenna Problem
