Key - headlight chime module
Old Mar 27, 2011 | 02:40 AM
wstrysko's Avatar
wstrysko
Default Key - headlight chime module
Anyone know where the chime module for the headlight
on - key in ignition is located on a 86 coupe ?
there is some kind of sound module directly above the drivers
seat on the pilar under the plastic trim, might that be it ?
if not, whats that one for ?
Thanks for the help.
Old Mar 27, 2011 | 10:15 AM
ecorse66's Avatar
ecorse66
I replaced mine several years ago. Its in the center dash near (above, behind?) the radio. It's a little rectangular plastic module a couple of inches long. I found picture in the manual, but I couldn't find a way to paste it here. Good Luck!
Dave T.
P.S. I believe the module above the driver is a temp sensor for Vettes with the C68 Electronic A/C
Old Mar 27, 2011 | 10:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Behind the info panel.
Diagnostics from my 86 FSM >> http://members.shaw.ca/agent86/Chimes.pdf
temp sensor for climate control
Old Mar 27, 2011 | 10:09 PM
wstrysko's Avatar
wstrysko
Once again, Thank You Agent 86.
To Key - headlight chime module
