Headlights
Old Apr 24, 2011 | 09:19 AM
bigdave71's Avatar
bigdave71
2nd Gear
Default Headlights
Buddy of mine replaced the gears in his 88's headlight motors. Once reassembled when operated one closes one opens.
Old Apr 24, 2011 | 01:34 PM
ecorse66's Avatar
ecorse66
I don't know what in the mechanical drive of the headlamp motors would cause that, but there may be some issue with the way he reassembled the motor. Reversing the polarity of one of the motor connectors would cause that problem. Check the polarity of the connector for the motor that is 'down' when the headlamps are on. Maybe use a couple of jumpers to temporally reverse the polarity to see if it cures the problem. Maybe someone here with more experience on late C4 headlamps will chime in.
Dave T.
Old Apr 24, 2011 | 01:40 PM
aminnich's Avatar
aminnich
He put the linkage arm on backwards. The one with the roll pin.
Old Apr 24, 2011 | 01:48 PM
bigdave71's Avatar
bigdave71
2nd Gear
thanks will pass on the info.
Old Apr 24, 2011 | 02:12 PM
ecorse66's Avatar
ecorse66
Much better answer than mine. Thanks!
Old Apr 24, 2011 | 02:41 PM
oldalaskaman's Avatar
oldalaskaman
this is excellent info, respectfully, bob
Old Apr 24, 2011 | 08:52 PM
mmercer's Avatar
mmercer
If that is not it (above) one of mine initally would not open upon rebuilding both and I discovered that I over tightened the worm gear adjustment.... (?) good luck...
To Headlights
