grounds where on 85
That's the major one, here's a list of grounds from my 86.G101-near RH side of battery, on frame.
G104-on block, above oil filter
G115-on frame, behind LH park/turn lamp
G116-on frame, behind RH park/turn lamp
G117-LH side of engine compartment, on front cross member
G125-behind RH kick panel
G201-behind I/P, near LH side of steering column
G320-LH B pillar
G400-on frame, above LH rear wheel
G401-base of RH B pillar
I have the FSM, and I'm trying to see if my misfiring is caused by a bad ground. They have pics for a lot of other parts of the car. It would have been nice if they had done the same here. the descriptions are OK, but could be better.
