Cam install
Old Jun 14, 2011 | 07:41 PM
slickfx3's Avatar
slickfx3
Default Cam install
Okay I am finally going to pull the trigger, anyone in the Los Angeles area want to help me do a cam change, I will pay you a fair fee.
Old Jun 17, 2011 | 06:41 PM
slickfx3's Avatar
slickfx3
never mind found a few shops, that can do it for me, I can wait to finally have the right cam in it....
Old Jun 18, 2011 | 08:25 AM
Paul Workman's Avatar
Paul Workman
Ah...if only life were that simple again...
Interesting specs on that cam. Looking forward to some dyno sheets, as I'm always curious about "power under the curve" results from this vs. that profile.
I B a watchin' U!
P.
Old Jun 18, 2011 | 11:07 AM
Muffin's Avatar
Muffin
What are you doing about a tune? MAF will work with some rather large changes but I'm guessing you are over the line with that lump stick.
Old Jun 18, 2011 | 11:45 AM
slickfx3's Avatar
slickfx3
going down from a Comp 230/236 280 xfi
my Auto-prom was put away months ago, literally now I am on third gen reviewing stuff , so I can re tune for the smaller cam.
it should not be that much of a difference in timing and fueling... I hope, should be fun to tackle.
Old Jun 28, 2011 | 02:55 PM
slickfx3's Avatar
slickfx3
Okay, so the shop an I need to know if the steering rack had to come out? I think I know the answer, but maybe one of yous know a trick or 2. the damper puller won't fit, any other consideration after we pull the damper? do i have t lift the engine?
another thing is the distributor gear is wearing funny, any idea what is causing this? cam shaft end play?
Old Jun 28, 2011 | 03:34 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
You need to unscrew the PS line that goes into the top of the rack. There is a small loop in the line but it is not big enough to fit the end of the puller.
Old Jun 28, 2011 | 06:23 PM
slickfx3's Avatar
slickfx3
just unscrew the line? and there will enough clearance?
Old Jun 28, 2011 | 11:17 PM
mtwoolford's Avatar
mtwoolford
excessive play between distributor gear and distributor body; any speed shop can sell you a shim kit.
Is your engine a factory roller? if so, the front of the cam is retained by a retainer plate which eliminated fore and aft movement of the cam.
bad oil pump with excessive internal drag, just plain overloading the gear?
Old Jun 29, 2011 | 04:49 AM
slickfx3's Avatar
slickfx3
yeah they figured out how to pull the damper, thanks Kubs you are right
the cam is stuck half way, hitting the cross member, need to loosen the motor mounts.
some think the dist gear wear is the result of the 280 xfi cam gear being new and the worn 150k mile old distributor accelerating wear, some thinks it's the hardness of the comp cam gear, no consensus.
should I replace with steel?
the shaft in the dist housing is nice and snug no slop there.
the cam roller chain retaining bolt had too thick washers on them and brushed up against the timing cover,we discovered, glad I have it apart.
Old Jun 29, 2011 | 04:55 AM
slickfx3's Avatar
slickfx3
Default Now for the good chit
I decided to have Ron ( cusinartvette) do his magic on my Super ram, so I dropped it off today and he is making great time with it and it looks nasty! check it out!
Old Jun 29, 2011 | 07:12 AM
drmrman's Avatar
drmrman
Good luck! cant wait to see this thing together! Take vids.
Old Jun 29, 2011 | 07:29 AM
wnafly's Avatar
wnafly
Old Jun 29, 2011 | 09:13 AM
Kubs's Avatar
Kubs
No problem. when I did mine I only took the bolt out of one motor mount and jacked up the engine a bit. If I remember you only need a little bit more clearance.
Old Jun 29, 2011 | 10:59 AM
slickfx3's Avatar
slickfx3
That was a new HV mellings that went in 18,000k mikes ago, the oil pressure has been creeping down since new, how do you measure dist shaft play, it was a stock configuration from the factory with one shim
Old Jun 29, 2011 | 11:02 AM
slickfx3's Avatar
slickfx3
should I buy a new timing chain?
Old Jun 29, 2011 | 02:08 PM
slickfx3's Avatar
slickfx3
Default Comp Cam issues
To Cam install
Old Jun 29, 2011 | 03:16 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Good thing you got that apart when you did!
Old Jun 29, 2011 | 07:18 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
How much time on the cam?
That kind of galling on the cam lobes I'd expect to see from a flat tappet cam.
Were the springs close to binding?
Old Jun 29, 2011 | 08:14 PM
slickfx3's Avatar
slickfx3
18k on the build, pistons, head, cam, one lobe is starting to look like the bad one, I think the BS started miles ago, luckily, we caught it, any more grinding and the crap would have had a field day on the bearings and bye bye engine.
the 8019 springs were an upgrade from AFR and can handle max lift .650, I was at .575.
Comp said valve floatation/tappet bounce can undermine the hard surface, I think it is a bad cam, out of warrantee, but they sold me one at cost,....
