89 Vette problems Please Help
Old Jun 15, 2011 | 01:33 PM
buzzmaniandevil's Avatar
buzzmaniandevil
4th Gear
Default 89 Vette problems Please Help
Hello, I am a first time vette owner and I am having a few issues that I need help with. First off, here is what happened. My car overheated and blew the side off of the radiator. After it cooled off I had to get the car home so I drove it about 10 miles to my house to put in the garage and it was a cool night and there were no stops all the way home. The car never shut off on me but when I backed it in the valves started chattering and I shut it off. I noticed the fan never came on so I rerouted to use a toggle switch manually to turn the fan on. My gauge cluster does not work so I did not even know it was running hot until I blew the radiator. With the new part in and filled with fluid I tried to start and the motor just turns over but it will not fire to try to start. My service screen in the center works and it shows the service engine light and the little battery light in the bottom corner which has never come on. Could this be a battery problem or where should I start? I ran it hot to get it home so I hope this is not why I can not get it started. Thank you to anybody that can give me some suggestions.
Old Jun 15, 2011 | 01:37 PM
Daniel_Mc's Avatar
Daniel_Mc
Is the car smoking? Have you checked the oil to see if you had coolant in the oil?
Daniel
Old Jun 15, 2011 | 01:55 PM
buzzmaniandevil
4th Gear
The car was not smoking and I had someone following me home in it. I checked the oil and it is a little dark but there is nothing in it but oil. I put a set of jumper cables on it and it still did the same thing. It would turn over fine but not start.
Old Jun 15, 2011 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is there spark at plugs ?
Do you have a noid light ?
Do you have a fuel pressure gauge ?
Old Jun 15, 2011 | 06:28 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by buzzmaniandevil
Hello, I am a first time vette owner and I am having a few issues that I need help with. First off, here is what happened. My car overheated and blew the side off of the radiator. After it cooled off I had to get the car home so I drove it about 10 miles to my house.
You drove your overheated Corvette with no water in the cooling system for 10 miles?
Old Jun 15, 2011 | 07:38 PM
John A. Marker's Avatar
John A. Marker
Pull the codes stored in the computer as a start. Agent86...check for spark....check for fuel.
Old Jun 15, 2011 | 08:00 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Old Jun 15, 2011 | 08:23 PM
buzzmaniandevil
4th Gear
Yes I did, I would rather have to rebuild the motor than leave my beautiful corvette on the side of the road. I asked for help not insults. If you had a nice vette you wouldnt leave it sitting either and you would do what you had to. I just need help fixing it
Old Jun 15, 2011 | 08:31 PM
buzzmaniandevil
4th Gear
I am getting fuel at the fuel rail. It just turns over normal, not fast but like it would before it starts but it doesnt start. I checked the plug wire with a screw driver but no spark so if the overheating was the problem how does the coil or my fire just go out like that? If i am getting no fire from the plug wire then what am i looking at?
Old Jun 15, 2011 | 08:36 PM
John A. Marker
I you blew out the side of the radiator...you have coolant thrown about the engine. That much coolant in the engine compartment may have shorted out something......Check the distributor cap....any moisture. Are you getting electricity to the red wire on the distributor?
To 89 Vette problems Please Help
