Flickering Interior Lights & "Door Ajar" indicaor
Hi folks, here's my issue:
91 Converitble, 106,000km
My interior lights are flickering on and off, and the "Door Ajar" dash indicator flickers as well:
When Im at highway speed, if i hit rough road/bumps - just the "Door Ajar" seems to come on
When im at slower speeds, hit a bump, uneven ground, rounding a corner, or transitioning from the flat sidewalk to my uphill driveway (body flex?) the interior lights come on. they go off again when the car is back on flat ground.
from reading other threads here, I suspect a door switch (would cause both symptoms), but i still have 3 questions:
1) Can the Door Switches be shimmed ? ie i suspect if a small amount of flex in the body is causing it a shim may solve the issue. I cannot see and flex inthe door fitment when i look.
2) where can I buy a "Quality" replacement switch in Canada
3) could it be something else ?
thanks !
thanks !
The switches can be adjusted. If you look at the end of the plunger of each switch where it contacts the body, there is a round head. Pry/pull that out with a small flat blade screwdriver. When you close the door for the first time, it'll push that pin back in to the correct length.
I had this issue with my 91 too. There is some sort of sensor on the door. On the door itself, it looks just like an aluminum half hook. It fits into an "O" shaped sensor on the door frame. It wasn't making good contact or something along those lines. I got some Isopropyl alcahol and some pipe cleaners. Cleared right up.
Your Lucky Day
I have the answer. Send me $100 in small bills.
Same EXACT symptoms had me replacing both door switches. That was a pain and cost $. Nope.
Your door latch post thingy is loose on one of the doors frames, probably drivers. It takes a big torx but I used a vice grip.
Let us know if I'm right. I drink Bud if you can't send money.
It drove me berzerk for a week. Ruined the car. Good luck.
Checked those metal hooks, all are tight, cleaned both the hooks and recievers with Isoprop Alcohol, no difference. Ill play with the plungers for the lights next.
Now my Battery is dying too, car barely started this am probably need a boost to start it tongiht when I get off the train. First attempt at startig it last night and this morning it really laboured to make any turn of the engine, second try it started just fine.
Ill have to get the alternator and the battery checked out too
Also add a little lubrication to the part of switch that moves in and out, not the adjustment button part.
Check the door seals (rubber around door) for excess play. Might be the door could be going in and out slightly.
Sorry I wasn't clear. Check the striker, the thing that sticks out of the frame that the hook in the door closes on. It screws in. Mine was loose causing the door to move enough to jiggle the plunger switch activating lights and door ajar light, your same problem.
The switches are self adjusting. Pull the little piece out and the next time the door closes it's adjusted. But I bet it's one of the strikers.
Well, all the door hardware and switches looked ok. Problem persisted until.... I investigated the cause of my difficulty starting the car sometimes. Turns out I had a loose battery terminal wire. Snugged it up and my starting issues are gone as are my issues with the Door Ajar and flickewring lights ....odd
Low voltage makes these computer filled cars do all kinds of spooky stuff. My airbag light started coming on in my wifes car. Battery was going soft. New batt = no more problem.
