distributor cap remove help
Old Sep 19, 2011 | 12:57 PM
hitmanpty's Avatar
hitmanpty
Default distributor cap remove help
I need help to remove my distributor cap. in my 1986 vette.
I enconter a problem when I try to remove rear screw. in the back part of the distributor cap. my hand dont fit in so small space. is there any special way to remove this. since the space between the fire wall and the distr.cap is so small
Old Sep 19, 2011 | 01:10 PM
oldalaskaman's Avatar
oldalaskaman
loosen the distributor hold down clamp and rotate the distributor
Old Sep 19, 2011 | 01:23 PM
hitmanpty's Avatar
hitmanpty
thanx
Old Sep 19, 2011 | 01:25 PM
hitmanpty's Avatar
hitmanpty
also any body knows a good DIY for c4 engine tuneup.. I think Iam going to try it by my self. since all the mecanics I know are to busi for me
Old Sep 19, 2011 | 01:31 PM
Sparkytfl's Avatar
Sparkytfl
Just remember to reset your timing advance when you're done.
Old Sep 19, 2011 | 03:20 PM
stoydido's Avatar
stoydido
3/8 ratchet extensions are too thick. I use a screwdriver "nut driver" with 1/4" socket on it, with 1/4" drive extension if needed. if all you're doing is removing the cap, no need to rotate the distributor, unless you plan on timing it. because you'll have to.
Old Sep 19, 2011 | 03:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I put a 6" extension on my hand driver.
Old Sep 19, 2011 | 03:30 PM
stoydido's Avatar
stoydido
I missed this part. If you need a guide, a manual, the Haynes is ideal for what you are doing. The Factory Manual is more comprehensive, but is intended for trained GM techs, not the diy'ers. also, your 86 version of the FSM is not readily available.
Old Sep 19, 2011 | 03:59 PM
Muffin's Avatar
Muffin
Thank you. I thought I was the only person on Planet Earth that thought that.
Let me rephrase that: IF you are going much beyond a simple tune up the FSM is absolutely essential. There are some DIY'ers who, me being one, who get far deeper that the Haynes level.
Old Sep 19, 2011 | 05:57 PM
hitmanpty's Avatar
hitmanpty
I will try with the screwdriver
Old Sep 19, 2011 | 10:54 PM
HlhnEast's Avatar
HlhnEast
And I removed the 30 screws that holds the drip edge to the cowl. Kinda more work than necessary but it worked great and allowed access to do what I needed. Didnt have to mess with the timing that was already fine tho.
To distributor cap remove help
