umplug wire ID please
Old Oct 11, 2011 | 12:34 PM
hitmanpty's Avatar
hitmanpty
Default umplug wire ID please
here we have some umplug connectors. coming out of the same wiring harnes of the fuel injectors .
I want to find out where this plugs go.
also I have some sensors that are not conected.1. brake sensos,
2.temperature sensor on front of engine, also 3. oxigen sensor on the exahust.
trying to make this right.
here are some pics of the connectors ans couple of sensor.
[IMG][/IMG]
[IMG][/IMG]
here are pics of some sensors
brakes
[IMG][/IMG]
sensor on top water pump front engine
[IMG][/IMG]
no pics of oxigen sensor. but is disconected also
Old Oct 11, 2011 | 01:24 PM
1963SS's Avatar
1963SS
You've got to get the sensor above the water pump hooked up. It could be the cause of a lot of your problems. All my books are later but I'm sure somebody will chime in with the proper information.
Old Oct 11, 2011 | 03:24 PM
hitmanpty's Avatar
hitmanpty
I know.. I want to have that sensor hooked. iam sure the cable have to be one of those on the pictures. just dont know which one
I want to have all my sensor hooked.
Old Oct 11, 2011 | 04:07 PM
hitmanpty's Avatar
hitmanpty
any body have any wild guest???
Old Oct 11, 2011 | 06:26 PM
Chuck Tribolet's Avatar
Chuck Tribolet
What year Vette?
What are the colors of the individual wires?
Old Oct 12, 2011 | 09:08 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Connectors pictured are for the A.I.R. valves, which are no longer on your car. Cut off the connectors, tape ends of wire and tuck them into loom.
The brake pressure switch wire comes out of main harness, just below master. The main fan relay wiring, leaves harness in the same location.
The coolant temp sensor wiring is in passenger side injector loom. Wire colours are yellow and black. The connector shape will match the sensor connection. Only MAT uses the same connector, and it's under plenum.
O2 sensor wire is purple. My memory says it come out of harness, just short of fuel pump relay.
Save this, it will help. http://members.shaw.ca/corvette86/En...agram%2086.pdf
Old Oct 12, 2011 | 09:20 AM
WW7's Avatar
WW7
http://www.jimsperformance.com/carty3.html
Old Oct 12, 2011 | 10:01 AM
hitmanpty's Avatar
hitmanpty
I have much to learn master Yoda. the force is strong on you.
Old Oct 12, 2011 | 10:04 AM
hitmanpty's Avatar
hitmanpty
Old Oct 12, 2011 | 10:10 AM
hitmanpty's Avatar
hitmanpty
Originally Posted by Chuck Tribolet
What year Vette?
vette is an 86.
thank you for your interes but Agent 86. all ready aswer all my questions.
thank you again
Old Oct 12, 2011 | 10:34 PM
Pwnage1337's Avatar
Pwnage1337
Got one from him, and its AMAZING. The thing looks brand new.
To umplug wire ID please
