93 dash problem
Old Oct 24, 2011 | 09:13 PM
dan2073's Avatar
dan2073
5th Gear
Default 93 dash problem
center lcd display will go blank and if you bang it or hit a bump it will come back is there a plug somewhere that could be loose any thoughts
Thanks Dan
Old Oct 25, 2011 | 01:44 PM
C4fan's Avatar
C4fan
St. Jude '10
Thanks Dan
Mine would come and go from time to time. Take the dash out (do yourself a favor and drop the steering column first). The dash is not hard just a few screws holding it in. It will unplug from the wire harness, no cable, the whole thing unplugs. All I did was replace the bulbs that backlight the screen. The rest of the bulbs I took out one by one and re-seated them. Then I plugged it back in. It has worked fine ever since. Sounds like your is like mine and just needs to be re-seated or unplugged and replugged. I would start there.
Old Oct 25, 2011 | 05:45 PM
illenema's Avatar
illenema
Thanks Dan
Well that could be the plug that connects directly into the cluster its something like 32 pins, or maybe check the 5 amp fuses on the fuse box there are 2 one for lcd and 1 for logic circuitry.
Then there is the dreaded connectors to the CCM behind the dash or a bad lcd portion of cluster. good luck
Old Oct 25, 2011 | 07:52 PM
dan2073's Avatar
dan2073
5th Gear
also forgot to say that when it goes blank the orange parts stays lite i just looses al the display info
Old Oct 25, 2011 | 09:20 PM
RedTRex's Avatar
RedTRex
FYI....
http://www.corvetteactioncenter.com/...0/008/article/
Old Oct 25, 2011 | 09:41 PM
illenema's Avatar
illenema
Thats not good. its the signal from the ccm or the logic fuse not lcd fuse. still be a loose connection on the connector pictured in the link. Might want to swap out a Known good display to see if its the display.
Old Oct 26, 2011 | 05:28 PM
sailorsteve's Avatar
sailorsteve
When you get in there, it wouldn't hurt to check grounds, too, There are a bunch of them.
To 93 dash problem
