oils
Old Nov 26, 2011 | 11:30 AM
19774x4's Avatar
19774x4
Default oils
what is the best oil to use with a flat tappet cam
Old Nov 26, 2011 | 12:12 PM
Marv02's Avatar
Marv02
I was using Valvoline racing oil it has Zinc in it you can get at NAPA auto parts, But you have to ask for it it's not normaly out on the floor it in back it for off road use only because of the Zinc in it.
Link:
http://www.valvoline.com/products/co...g-motor-oil/6/
I now have a roller motor so I dont use it any more.
Other wil tell you Gibbs Oil, AMSOIL all great oils but you have to order them and wait for the oil show up in the UPS truck, while the Valvoline At Napa.
Old Nov 26, 2011 | 01:10 PM
19774x4's Avatar
19774x4
Default oils
thanks for the help.
Link:
Other wil tell you Gibbs Oil, AMSOIL all great oils but you have to order them and wait for the ol show up in the UPS truck, while the Valvoline At Napa.[/QUOTE]
Old Nov 26, 2011 | 01:17 PM
Kris_K's Avatar
Kris_K
Look into Mobil 1 0W40 European Formula. It has plenty of Zinc in it.
Old Nov 26, 2011 | 02:30 PM
19774x4's Avatar
19774x4
thanks for the help, i will ck it out
Old Nov 26, 2011 | 05:11 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
http://forums.corvetteforum.com/c3-t...ppet-oils.html
http://forums.corvetteforum.com/c1-a...ils-myths.html
read. but to help use Shell Rotalla
Old Nov 26, 2011 | 05:18 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Relatively new synthetic designed specifically for this type of application:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
I'm more than happy to get the above for forum members at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 27, 2011 | 08:45 AM
Geardo's Avatar
Geardo
Royal Purple HPS
Old Nov 27, 2011 | 09:22 AM
VetteMed's Avatar
VetteMed
Mobil-1 High Mileage Formula has added zinc, and is readily available.
Old Nov 27, 2011 | 10:55 AM
ToniH's Avatar
ToniH
No-one can say which is the best but: there is quite comprehensive list of flat tappet oils in C3 tech: direct link
No it doesn't, not even close enough for flat tappets.
Nope, not quite enough either.
Here is a list for Mobil oils, only their 15W-50 and racing oils have enough zinc in them for flat tappets.
Shell Rotella = diesel oil, different additive set than gasoline engines. I wouldn't use it in high performance application.
I use Redline 10W-40 (in BBC) which has about 1330ppm of zinc in it.
Old Nov 28, 2011 | 09:47 AM
19774x4's Avatar
19774x4
thanks guys for all the info, this is a great forum
Old Nov 28, 2011 | 09:52 AM
19774x4's Avatar
19774x4
Link:
thanks
Old Nov 28, 2011 | 01:51 PM
Geardo's Avatar
Geardo
Shell Rotella is a great oil, used by many motorcycle drag racers, I use it in my bike, and I turn up to 12,000 rpm, makes a SBC look very slow in comparison
Old Nov 29, 2011 | 11:09 AM
19774x4's Avatar
19774x4
thanks you guys are great
To oils
