Several of us on this board have installed our own OBX headers. I for one did not find the task overly difficult. It was time consuming, not for reasons related to the headers design - I spent most of my time fighting to get the AIR tube nuts loose from the original exhaust manifolds. As previously mentioned, I did have to dent one pipe to make clearance for a bracket. I view that as par for the course when installing aftermarket headers in a tight engine compartment. I notice that a lot of negative comments are made against OBX headers because they are made in China. I hate to break it to the nay-sayers, but these import headers are of high quality, and on par with what I have seen from domestic manufacturers. I think that the reason some here are so quick to knock OBX headers is because they payed far more for a product that is no better. Generally, most people want to get the best bang for their buck. Myself and at least one other gentleman on here saw the 1/4 mile ET's on our mostly stock LT1 Corvettes drop by 4/10's of a second, just by installing OBX headers. I still have the stock exhaust from resonator back. For a $490 investment, that's tough to beat. Back to the original topic, I don't think it would matter what brand of headers the original poster purchased - he would not be satisfied. Long tube headers simply are not a "direct bolt on".
I grabbed the Hedman Headers (the cheapies), put them on myself in the back yard, drove to the muffler shop. They put on 2.5" stainless duals with an X-Pipe and Magnaflow mufflers and added O2 sensor bungs on both sides.
Total cost - $550.00.
May upgrade to the Elites because they look nicer.
FWIW - did help a buddy put on OBX headers on his 2010 Mustang GT (smoking deal at $275 shipped with the H-Pipe). Took me about 12 hours without any custom fab. Had to completely remove the motor mounts to get them in. The headers are very nice. Made me appreciate the Vette and it's "component location".
The OP should have done his homework first. I did before i got mine . I pm girvin02 and he graciously went out of his way to walk me through everything. Sent me pics ,gave me measurements for spacers etc. Me being an old fart and lazy took it to a local muffler shop. I had the spacers cut i my garage and ready to go. Cost me 150 to install. Of course i stood there and made sure it was done right.
I lucked out I was given my TPIS headers for free.
I made friends with the owner of the local NAPA store he had them on his Vett before he got rid it for a ZO6 C5 and he said they were lay in middle of Isle way an got tired of tripping on them so he gave them to me.
the way i see it, for the price, the obx headers are definitly worth it. only problem is the size, i hear alot of talk about how the smaller primaries are going to rob power.
Just out of interest, how far away from the original cats do the new cats sit after installing headers (any mentioned)? I understand that the reason LT headers are not legal here in Cali is because they move the position of the original cats?
Could be talking out my **** here, but in theory if you can get the original cats to sit in the same position, it would pass an emissions inspection?
My father and I installed my hedman longtubes in his garage and it wasn't bad. I bought header bolts and had no intention of using the stock ones. Our biggest fight was the starter but I didn't have to dent anything our modify brackets. Headers and copper gaskets-I'm out $200. When they rot I will pony up for nicer ones.
I would like to thank crzydrumer14 for his experience with the OBX headers. Too many people are giving him crap about how he should have known that the headers need some fabrication to fit.
I went through aftermarket parts not fitting properly back when I had my '83 Z28 Camaro. It was highly modified by me and I became well versed in fabricating brackets and every other part of the car.
The problem is the aftermarket makes some great products that fit perfectly and too many that don't (requiring lots of fabrication).
So I applaud crzydrumer14 for letting us know!
Lets not bash him for his candid experience.
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
Originally Posted by LT1*C4
To assume that because a cheap set of chinese headers require the customer to perform additional modifications in order to get them to fit properly - ALL other header brands must require the same amount of tweaking as well, is nothing more than an excuse made by someone trying to defend a shoddy product.
For the record, there was absolutely no tweaking/bending or hammering of any sort with my AR header install. They practically fell into place. Best fitting headers I've ever run on any car I've ever owned and I've installed more headers than I can remember.
- and a little off topic, but you spent how much to install your OBX's? $800? Wow.
Your mechanic must have seen you coming from a mile away. Even at an hourly rate of $100/hour (I'm guessing) - that would have meant he spent 8 hours to install your headers?
Either he ripped you off, or those little obx headers required a lot of screwing around/additional parts/modifications to get them to fit properly. Either way, sounds as if you got dealt the short end of the stick.
For what you spent total out of your wallet, you could have bought the entire ARH system system (headers/xpipe/cats/intermediate pipes - basically an entirely new exhaust system besides mufflers) and installed it yourself in your driveway in about 3-4 hours with simple hand tools for nearly the same cost. That's 3-4 hours for a novice mind you, if you've done a header swap on these cars before, install time would be much less than that.
Live and learn, I guess...
To the OP, sorry to hear about your troubles with the install. You're right, a product should always perform as advertised. If additional modifications need to be done (no matter how small), it should be stated in the advertising so there's no surprises for the customer. I hope you figured it all out and your car's ready for the road again. Best of luck with it.
To begine with You not being a "novice" are trying and I mean trying to tell me you can install long tubes on a LT1 in less than 3 hours in your driveway. I want what you are smoking.We have 60 minutes in one of our hours, there must be twice that in Canada.
There is zero possibility on an LT1/4 car of locating the cats in the stock location with LT headers. The cats are located where the pipes merge into the collectors.
We have 60 minutes in our hours too, I assure you. I don't know what me living in Canada has to do with the subject, but you seem to have a knack for ignoring the issue at hand and resort to posting ignorant comments to try and sound funny.
For someone who had to pay someone else to work on their car for them, how the hell would you even know how long a header install takes to question my statement and call me a liar?
I, unlike you, actually do all my own work to my car and yes, swapping out my old EM Long tubes for the AR headers took less than three hours.
First you claim obx is on the same quality level as the high-end brands (in another thread) despite not actually having experience with any of the higher end brands - now you refuse to believe that your mechanic overcharged you on labour.
You're the one who agreed to pay $800 to install headers on a sbc. If anyone here is smoking anything, it's you.
We have 60 minutes in our hours too, I assure you. I don't know what me living in Canada has to do with the subject, but you seem to have a knack for ignoring the issue at hand and resorting to dumb-@ss comments to try and sound funny.
For someone who had to pay someone else to work on their car for them, how the hell would you even know how long a header install takes to question my statements?
Once again, you're in denial. First with your claima that obx is on the same quality level of the high-end beands (in another thread) - now with your refusal to belive your mechanic screwed with labour charges.
You're the one who agreed to pay $800 to install some headers. If anyone here is smoking anything, it's you.
Good day sir.
Like I said I want what you are smoking, at least I tell the truth and not try to pat my self on the back with BS humor about how good and great I am. You remind me of a guy at work who could do things in half a day that took all day. Do you really think anybody here really believes you here. Good day and you are right in calling me Sir, Sonoh yea how is Corvette Mike did he put Ghost flames on your headers for you.
These header brand threads are getting old, l could not do mine myself due too health reasons so I had to pay to get them installed and don't need a Mr GoodWrench telling me his comments about me paying for it
