knock sensor
Old Jan 20, 2012 | 11:03 PM
sweetbaboon's Avatar
sweetbaboon
Default knock sensor
how do you unplug the knock sensor, I am afraid that I will break it if I pull on it to hard.
Old Jan 20, 2012 | 11:25 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
This is a picture of the knock sensor.. http://htsmall.ecklerscorvette.com/a.../sku/34668.jpg
Old Jan 20, 2012 | 11:45 PM
sweetbaboon
all ready looked at the picture, did not help me.. i break more plastic connectors than i am able to successfully remove
Old Jan 21, 2012 | 12:24 AM
ccrazor's Avatar
ccrazor
It should pull off without breaking the sensor, with the one on my 84, which is a similar style, a steady pull and a couple of wiggles and the connector came off. If you should break the sensor Ecklers has them for about $40. LOL
Old Jan 21, 2012 | 12:59 AM
vetteoz's Avatar
vetteoz
No point asking same question twice
http://forums.corvetteforum.com/1579793186-post9.html
loaded vet's Avatar
loaded vet
Default Electrical connector pinch
You need to pinch the sides which opens the retainers on each side snapped over a round bulb looking insulator. If you simply pull on it you will break the connector housing. to put it back on you just push on it until it snaps. You are hooked up. Hope this is helpful.
Gary
To knock sensor
