stereo setup HELP!!
Old Mar 27, 2012 | 06:25 PM
Need4Speed90's Avatar
Need4Speed90
Default stereo setup HELP!!
hey everyone ive looked everywhere and read everything but im still confused. i want to install and aftermarket headunit and keep the stock bose speakers and rewire the car woth new speaker wire.. what do i need? i know i need some kind of harness and an instillation plate but im not even sure what kind of harness i need or if my setup is even possible.. all 4 amps of mine are blow.... thanks in advance
Old Mar 27, 2012 | 06:36 PM
RLG's Avatar
RLG
I would suggest that you buy new speakers and run new wires. the small wires that power the amps are a little light.
you need the harness to bypass the radio control unit behind your glove box. You don't need to remove just unplug and use the harness and wire up the new head unit. you will need to install two .5 ohm resistors into the factory harness behind the radio head.There is a TSB on it here somewhere. You will need the mounting bracket as well, I don't recall the brand but it starts with an M. Crutchfield has the harness (I think) I got mine from a local stereo shop. oval 6x9 work in the back and round 5 1/4 works in the door sill.
Old Mar 27, 2012 | 07:25 PM
c4cruiser's Avatar
c4cruiser
You should find all the answers to your questions in the Audio/Electronics section of the Forum.
There are Supporting Vendors that can help you with getting the equipment and accessories you need. Check with Dennis at Double D Mods. He will be more than willing to help you do a conversion.
Old Mar 28, 2012 | 08:25 PM
Pwnage1337's Avatar
Pwnage1337
I think the brand you are thinking of is "Metra"
To stereo setup HELP!!
