Code 41 on C4 1993
Old Jun 12, 2012 | 03:56 PM
Herbee's Avatar
Herbee
4th Gear
Default Code 41 on C4 1993
Is any one can help I changed , new distributor, Ignition coil, ignition modul but still not working ,Start to run and dies ,must push gas pedal to keep engin running ,any help is welcome !Thanks
Old Jun 12, 2012 | 04:43 PM
1986coupe's Avatar
1986coupe
Is your PCM plugged in properly?
Old Jun 12, 2012 | 04:53 PM
Herbee's Avatar
Herbee
4th Gear
What is PCM ,ECM ?
Old Jun 12, 2012 | 07:18 PM
rodj's Avatar
rodj
Originally Posted by Herbee
What is PCM ,ECM ?
The computer that controls the engine
It has to "talk" to other devices in the car.
When it can't you get code 41 showing,potentially a very hard problem to track down
Read
http://forums.corvetteforum.com/c4-s...cm-or-ccm.html
Old Jun 13, 2012 | 04:53 PM
Herbee's Avatar
Herbee
4th Gear
Read
I fund the problem ,Ignition coil bad ,thanks anyway
Old Jun 13, 2012 | 04:56 PM
Sweet 90's Avatar
Sweet 90
Glad you found it
To Code 41 on C4 1993
