ASR - How does it work?
Old May 26, 2002 | 09:41 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default ASR - How does it work?
[Modified by Bluewasp, 9:06 PM 5/26/2002]
Old May 26, 2002 | 10:29 PM
bigdan's Avatar
bigdan
Default Re: ASR - How does it work? (Bluewasp)
just fine!!! :jester kidding. :lol:
i believe it uses the abs & other sensors to measure vehicle speed vs. tire speed to regulate throttle/abs/etc to limit tire slip.
[Modified by bigdan, 9:29 PM 5/26/2002]
Old May 26, 2002 | 10:32 PM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
The ASR works by applying the ABS to a spining wheel, pushing the throttle back, and finally retarding the timing of the car.
Old May 26, 2002 | 10:41 PM
MyC-4's Avatar
MyC-4
Default Re: ASR - How does it work? (90 Corvette ZR-1)
Exactly :crazy:
Old May 26, 2002 | 10:45 PM
carguru's Avatar
carguru
Yep, like the others said, uses ABS. It works by comparing the speed difference between the wheels. If it is a small differential, it applies brake to the wheel/wheels that are moving the fastest. If large differential, it cuts the amount of throttle and applies brake at the same time. :)
Old May 27, 2002 | 12:16 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: ASR - How does it work? (carguru)
I'm asking because today on the way home the roads where a little wet and I went into a turn at what I thought was a safe speed and the back end broke loose. I was able to recover but I noticed the gas pedal went to the floor when ASR light came on. Did the ASR save my butt or was it luck?
Old May 27, 2002 | 12:19 AM
scorp508's Avatar
scorp508
Is there a yaw sensor also?
Old May 27, 2002 | 12:20 AM
vader86's Avatar
vader86
might have, its fine to drive w/o it on dry roads, but i wouldnt in wet
Old May 27, 2002 | 12:28 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: ASR - How does it work? (vader86)
it took be by surprise. I was going about 25mph because the light was red then it was green and I started to make the right turn... I couldn't have been going more then 15 to 25.. oh well.. lessons learned! :D it wasn't a hard right but one that gives you a lane to make only a right and you have a merge lane after the right turn. The rain was light. Just enough to bring up the oil and dirt but not enough to wash it away.
[Modified by Bluewasp, 11:29 PM 5/26/2002]
[Modified by Bluewasp, 11:44 PM 5/26/2002]
Old May 27, 2002 | 12:29 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: (scorp508)
if it did then it would be like AH on the C5's... ????
Old May 27, 2002 | 12:39 AM
carguru's Avatar
carguru
Default Re: (Bluewasp)
Sounds like it read your rear wheel speed as being much more than the fronts and corrected your throttle. Believe it did what it was suppose to do. I've had mine catch me by surprise like that. It saved my butt from sliding off a slick onramp. Believe that this system works only with the tps and wheel speed sensors. Don't recall a yaw sensor.
Old May 27, 2002 | 12:43 AM
scorp508's Avatar
scorp508
Is there a yaw sensor also? if it did then it would be like AH on the C5's... ????
Thats what I was thinking, but wasn't sure. I'm pretty sure our ABS systems have a lateral accelerometer. That is side to side motion, correct?
Old May 27, 2002 | 12:45 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I think i posted this question in the wrong section! :)
Old May 27, 2002 | 02:15 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
ttt
Old May 27, 2002 | 02:52 PM
90 Corvette ZR-1
Trust me when the ASR kicks in you will know it. I was driving my friends 94 LT1 auto and I hammered it. The gas peddle literally pushed my leg (and I am not a week guy) back up off the floor.
Old May 27, 2002 | 03:02 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I know the ASR kicked in but I wanted to know if the ASR is like AH on the C5 and will recover the car when the back end goes out or is ASR like normal Traction Control...
Robert
Old May 27, 2002 | 03:13 PM
90 Corvette ZR-1
ASR = Traction Control
To ASR - How does it work?
Old May 27, 2002 | 03:15 PM
DSTJ99's Avatar
DSTJ99
I am pretty sure there are no lateral sensors. It kicks on only when your tires break loose. I have found it quite useful in avoiding sideways spins during wet weather driving.
"Corvette's ASR used engine spark retard, throttle close down, and brake intervention to limit wheel spin when accelerating." :flag
Old May 27, 2002 | 11:39 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: ASR - How does it work? (DSTJ99)
one time at band camp... oh sorry wrong forum, any ways one time I took an off ramp at 90 and the last 40 feet or so really got tight and the car slid over one lane before I could get in back (all 4 tires slid) MAN I set off a lot of things.. the ASR light came on and so did my check ABS and the check ASR light came on and stayed on untill i shut the car off .... that thing did not know what to do... It was kind of fun just glad there is no one in that lane... :cool:
Old May 28, 2002 | 08:15 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: ASR - How does it work? (MyC-4)
Exactly :crazy:
There's more to it than that, after I finish reading the book I bought on it, I can let you know.
