computer module?
Old Aug 27, 2012 | 05:19 AM
joedirt001's Avatar
joedirt001
Cruising
Default computer module?
is the computer module and ecm the same thing? if not any ideas where the module is on an 88 coupe?
Old Aug 27, 2012 | 07:52 AM
joe paco's Avatar
joe paco
for what reason are you looking? ECM is electronic control module, also has a vats module, central control module on later years.
also has ICM, ignition control module in distributor. modules communicate with the computer.
joe
Old Aug 27, 2012 | 08:38 AM
rodj's Avatar
rodj
If you are talking about the ECM ;the ENGINE CONTROL MODULE (called the ECU by some) that operates the engine it is mounted under the dash in your car
Old Aug 31, 2012 | 04:18 PM
joedirt001's Avatar
joedirt001
Cruising
anti mtheft module ? what and where is it ? it is not found in chiltons...
Old Sep 2, 2012 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Theft deterrent system has 2 parts.
VATS decoder module is behind the pad on passenger side of dash.
Theft deterrent controller is behind lower side of passenger side dash.
Some good reading from my 86 FSM
http://members.shaw.ca/dankai/Vats%20Electrical.pdf
To computer module?
