Tires
Old Jan 23, 2013 | 10:19 PM
Snaps's Avatar
Snaps
Default Tires
What is the smallest tire size you can fit on the 17" C4 rim?
Old Jan 25, 2013 | 10:03 AM
Snaps's Avatar
Snaps
Looking to do a burn out contest and dont wanna buy 255 or bigger.
Old Jan 25, 2013 | 10:55 PM
93Rubie's Avatar
93Rubie
it'll fit, just fine. Might look a little stretched (barely) but that is the style today. If on a 9.5 inch wide wheel.
Old Jan 25, 2013 | 11:49 PM
WVZR-1's Avatar
WVZR-1
Ain't that the shitzthough! And they get rather upset when your next to them at the traffic light smiling and pointing!
Old Jan 26, 2013 | 08:41 AM
Keystring's Avatar
Keystring
My 87 had 255 16 on a 9.5 rim and didn't looked 'stretched'.
That was stock size.
I have 255 on 9.5 17 rims now and they don't look 'stretched' at all.
Old Jan 26, 2013 | 10:49 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No, they won't look "stretched".
You didn't list the aspect ratio of your tire.
But a 9.5" rim is wider than the tread width of the 255/45-17 tire.
So, they do look a little funny (like being stretched in reverse).
The bead of the tire (at the rim) is wider than the actual tread width.
The factory used a 255/45-17 tire on an 8.5" rim.
Old Jan 26, 2013 | 12:17 PM
Keystring's Avatar
Keystring
255 mm = 10.0393700787402 inches
Old Jan 26, 2013 | 12:30 PM
WVZR-1's Avatar
WVZR-1
I don't believe the OP needs to be so much concerned with SIZE just age! There actually might be a benefit to a slightly larger diameter, get it rotating and it's substantially less effort to keep it rotating.
JUST NEEDS OLD HARD TIRES -
Old Jan 26, 2013 | 12:43 PM
Keystring's Avatar
Keystring
I understand.
But apparently it matters who the manufacturer is when comparing 'tread' width.
Especially since it varies between them.
As I said, mine seem to be fine.
Old Jan 26, 2013 | 12:44 PM
RollaMo-LT4
Your "tread width" is not 255 mm though.
255 is the section width.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
When I went to 9.5" wheels on the front of my '96, I at first wanted to keep the factory 255/4517 tire.
But they looked "funny". They "bulged out" where the bead meets the rim.
Once I put on the 275/40-17, they looked much better.
As I said above, the factory used an 8.5" rim with their 255/45-17 tire.
It is just a much better fit.
Old Jan 26, 2013 | 12:50 PM
ch@0s's Avatar
ch@0s
To Tires
