auto trans question
Old Apr 9, 2013 | 08:50 PM
Beezie's Avatar
Beezie
8th Gear
Default auto trans question
recently got a 91 Coup with auto trans. Just noticed today that just before I come to a complete stop I hear and feel a very slight bump. Seems to be happening when it downshifts to first gear. The trans seems to be performing very well other than this. Any thoughts? Thanks
Old Apr 9, 2013 | 09:19 PM
l98tpi's Avatar
l98tpi
Max G’s
Have you reset your detent cable yet to see if that would remedy the issue? If not, try that. And change the fluid and install new filter and fluid.
Old Apr 9, 2013 | 09:47 PM
vetteoz's Avatar
vetteoz
Mine did that when the uni joints were worn
Old Apr 9, 2013 | 09:57 PM
TommyFox's Avatar
TommyFox
2nd that.
Old Apr 9, 2013 | 10:20 PM
Joe C's Avatar
Joe C
i'm guessing you have the old downshift clunk issue. common 90/91 thing...
http://www.corvetteactioncenter.com/...ast+Down+Clunk
http://forums.corvetteforum.com/sear...rchid=35093976
http://forums.corvetteforum.com/sear...rchid=35093805
Old Apr 9, 2013 | 10:39 PM
Beezie's Avatar
Beezie
8th Gear
Thanks for the quick responses. What should I expect to pay to have the u joint replaced?
Old Apr 9, 2013 | 10:46 PM
Beezie's Avatar
Beezie
8th Gear
Originally Posted by Joe C
Does the trans have tobe removed to do this work? What can I expect to pay to have this done?
Old Apr 9, 2013 | 11:14 PM
383vett's Avatar
383vett
Sounds normal to me.
Old Apr 10, 2013 | 10:16 AM
Beezie's Avatar
Beezie
8th Gear
Default trany knock
Joe,
thanks for the links. I read them and they state this problem was solved in later model trans. The sound I am getting only started recently so I was wondering if this could be something else or would the sound happen even though the trans may have been a later model with the proper parts.
Old Apr 10, 2013 | 10:57 AM
tbirdsps's Avatar
tbirdsps
My 90 does that. But only in D3. The shop says it won't hurt anything but some people are annoyed by it.
Old Apr 14, 2013 | 07:02 AM
Joe C's Avatar
Joe C
same here - my 90 had the "clunk," and it was definitely worse in D3 than in OD. took it to both a dealer and an independent transmission shop - both said, it shouldn't hurt anything. probably just sounds worse than it actually is...
To auto trans question
