Water Pump Replacement ..........
Old Aug 2, 2013 | 03:58 PM
apolloshep's Avatar
apolloshep
Cruising
Default Water Pump Replacement ..........
I finally got my C4 inspected and went to the store then home. I backed up the car into the garage and midway up coolant started leaking all out. It is hard to see where it is leaking from but it is in the front middle part of the engine. I believe it to be ther water pump. There is no white smoke comming out of the exhaust.
I have worked on brakes and general stuff on cars for years. Does anyone have any advise as far as the difficultly of replacing it? And does it sound like the water pump? I can read REMFG written on the old pump so not new. A parts place says that I need to be driving it more often to offset repairs. In the last year I drove it maybe 1K. Is this an issue?
Thanks.
Old Aug 2, 2013 | 04:51 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
What year? You should fill out your profile.
Old Aug 2, 2013 | 05:15 PM
MrWillys's Avatar
MrWillys
I have a fear of Chinese made stuff, so I sent my out.
http://waterpumpman.com/index.html
Old Aug 2, 2013 | 08:10 PM
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
I replaced mine, nothing to be afraid of. Advise you take lots of digital photos as you take things apart, mostly electrical connections, so that you get them right. It saved me. I completed the job, but it would not fire, start. Looked at the photos and compared them to what I had done, and bingo, I had the coil connection on wrong...Dohhh!
Old Aug 2, 2013 | 08:45 PM
avigar's Avatar
avigar
Mine went at about 51,000 miles with my '91 two years ago. I had my local Chevy dealer fix it for me. Total was $411, with new serpentine belt, and taxes included. It was a new, not remanufactured, AC Delco water pump. The work was dealer warranteed, parts/labor, for 12 months. No more issues after that.
Old Aug 2, 2013 | 08:59 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Water pumps have a weep hole to let you know the seal has failed and bearing failure is soon likely.
That being said, the leak is generally very slow, so if yours leaks fast, I would be looking for a split hose or loose clamp, at or near pump.
Old Aug 3, 2013 | 12:39 AM
Cliff Harris's Avatar
Cliff Harris
Since you didn't specify a year... The L98s have a throttle body heater hose that is more likely to be your problem. It connects from the front of the intake manifold to the bottom of the throttle body.
If you do replace your water pump you'll have to remove the AC compressor mounting bracket because it's bolted to the water pump. That's fun... I don't know if it's possible, but it might come off if you remove the two nuts on the water pump bolts and the hidden bolt under the compressor that goes into the head. After doing that, the compressor and bracket might come off as a unit. Another fun aspect of this is that the fuel lines go through the compressor bracket. Maybe you can tell that I just did this last week...
My water pump was fine after 27 years and 116K miles but I replaced it with a Stewart "while I was in there" -- replacing a timing chain and a few other things.
Old Aug 3, 2013 | 01:40 AM
dogfish246's Avatar
dogfish246
It is all right here! Watch the video and you can do it!
Old Aug 3, 2013 | 05:00 PM
apolloshep's Avatar
apolloshep
Cruising
Default Water pump issue.....
Mine is a 1996 vette. Interesting about the weep hole being a slow leak it leak out about a 2 foot circle in seconds. So I am off next week will double check the hoses. At first glance I could not see a leak around the hoses. When I squeezed the upper radiator hose could here an air leak sound not sure if a weep hole would make this sound.
Old Aug 4, 2013 | 10:29 AM
WW7's Avatar
WW7
I have had water pumps go bad and leak slowly, but have also had one go all at once and dump coolant everywhere. If you want to see if its the waterpump leaking, place a folded paper towel directly under the weep hole of the pump. Then start and run the car up to temperture.. If the paper towel if soaked with coolant then you have your answer....WW
Old Aug 4, 2013 | 11:06 AM
apolloshep's Avatar
apolloshep
Cruising
What area of pump is the weep hole? Bottom, side ?
Old Aug 4, 2013 | 07:19 PM
Smokeysvette's Avatar
Smokeysvette
I agree with WW7. My '92 w/50K started leaking slowly. Took a towel and wiped the weep hole clean with brake cleaner then ran it for awhile. I then took a mirror and looked up at the weep hole sure enough saw it had leaked. Replaced the water pump and I was good to go.
Don't wait long or your going to be replacing the Opti also.
Old Aug 4, 2013 | 08:13 PM
hooked073's Avatar
hooked073
seldom do pumps blow large amounts of cooleant if the do the usaly bown the bearing also. grab the pully and see if you have a lot of play in it
Old Aug 4, 2013 | 08:19 PM
mxw128's Avatar
mxw128
If its a 96 ( therefore lt or 4) I'd be careful about running it too much more with the opti under there possibly getting soaked! You may end up with a bigger problem.
Old Aug 5, 2013 | 07:58 PM
apolloshep's Avatar
apolloshep
Cruising
Default Water pump .......
I m going to look for a bad hose if cannot find one then have it towed so I do not damage the optics park to my repair shop.
Old Aug 5, 2013 | 08:17 PM
lt4obsesses's Avatar
lt4obsesses
If you have a mechanics mirror or even a small hand mirror, look at the bottom side of the pump. There will see if there is coolant leaking from the hole. there is a soft diaphram in the pump that can dry out from under useage, this happened when I first got my '96.
As far as what you saw on the garage floor, what happens is that the coolant is leaked onto the serpentine belt and then thrown around the engine bay, it will pool in places and then come down.
Also check your hoses of course, and replacing them while the coolant is out is probably a good idea.
Old Aug 5, 2013 | 09:05 PM
Klyde's Avatar
Klyde
The weep hole should be directly over the belt and the belt should be flinging the coolant every where including the inside of the hood. If not then you probably have a popped hose down low.
To Water Pump Replacement ..........
Old Aug 5, 2013 | 10:30 PM
mrmtrtrnd's Avatar
mrmtrtrnd
How To: Water Pump Replacement LT1 - YouTube
Well done video and that should help anyone get through a replacement.
Old Aug 6, 2013 | 01:43 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
One thing some will attest to, let those little problems go on too long and you will be sorry.
And Cliff hit the nail when he replaced other parts while they are accessible.
Sure your gonna be hurting for cash for a few paychecks but the cost is worth ridding yourself of the hassle later on.
Old Aug 6, 2013 | 05:45 PM
apolloshep's Avatar
apolloshep
Cruising
Default 1996 vette water pump .........
I had the car towed to the shop today. They already called and said the pump was bad. They also recommend replacing the thermostat, which was a whooping 200 bucks for parts and labor. I told them to skip this. They were going to replace it cause the engine could have overheated. I never drove it anywhere except to move it to the road for the guy towing it.
They also said to replace the radiator hoses as well and said the heater hoses looked ok I told them to replace them. Total cost for all of this was 800.00 does this sound too much. They only use gm parts and are all new.
