One piece or "solid" flywheel
)Actually according to my research chatter is quite common when using a new findanza aluminum flywheel so I dont think mine contrasts anyone who has used the D/f set up with the Aluminum flywheel. Do a quick google search. There are hundreds of people who have had the same issue.,
When you said "pucks" I realized you're using one of those extra special grippy discs. In contrast, the Centerforce 381039 disc I/we use is a flat, sprung hub type and it works with the stock Veleo pressure plate AND the Fidanza, apparently.
Yes pucks...I.E. The clutch plate is not one solid piece but broke up in several segments. One side of the C/F is a solid composite plate and the other is a harder puck style. My clutch used with the findanza is below.
http://www.centerforce.com/products/...-crate-engines
Never had a moments problem with the Fidanza/Centerforce 381039 (sprung hub) disc/Veleo combo. (And there's a bunch of 'em running around in FBI land running north of 500 hp.) However! When you mentioned "pucks", the ONLY chatter problem one of us was having was with a single mass steel FW (not a Fidanza) and one of those "puck" type discs. Now you have me wondering if the maybe it is your disc too that is at the root of the chattering??
I dont believe so considering there seems to be several Issues from several sources using the D/f centerforce and findanza aluminum flywheel.
I dunno - just making an observation. I do know his was a pain to drive around town, as I recall. The ultimate cure to smooth operation w/o slipping was a dual disc RAM clutch conversion. The kit was built by RAM with the input from some ZR-1 guys, and the comment was made that "...for under 600 hp, it would be the last clutch you'll ever buy."
Getting off track a bit, but maybe worth looking into; a dual disc, whether it is made by RAM or CENTERFORCE or whomever might be the solution for your big hp application.
Here is my original pos from when I first intalled the clutch in my car. The chatter was so bad for the first 500 miles it was hard to bare. Now it has lightened up but as I said I do get some slip under hard acceleration. The clutch is rated for around 500 hp and I am over that but I didnt think it would cause these issues nor did I think it would slip this fast. When it goes out I will be going back to a single mass steel flywheel and a spec clutch.
http://forums.corvetteforum.com/c4-t...atter-bad.html
I've bought from them many, many years. They were and are still a premier manual transmission and transfer case parts source. I've no recent history with them. They're really big on their "Tranzilla" and their fluids.
http://www.rsgear.com/
I don't have to read internet to find contrasting experiences regarding the success of the Fidanza FW. I have first-hand experience, and that of half dozen people on my Android phone list. And, one of the busiest ZR-1 specialist in the country recommends them and has installed many. He's not a Fidanza rep and he is very conservative when it comes to recommending anything as it reflects directly on his credibility and on his one-man shop.
The attraction of the aluminum FW (for me) is the huge reduction of rotating mass. The DM stock FW weighs in around 43#, whereas the Fidanza is 13#. And, even in 4th gear (on a inertia dyno) the effective difference measures 15 hp: much higher in lower gears with higher rates of rotational acceleration; maybe double? I don't know what the dyno number is in first gear, but it makes a significant difference in first gear (especially), where the 315x35x17 (GY D3s) rear tires will break loose on the street almost at will w/o involving the clutch!
So, between your experiences with the D/f disc as it relates to using the Fidanza, and the opposite experiences that I'm personally familiar with, I'd say something is causing it that might be one or a combination of things causing the problem. And, because of the "free horsepower" (torque, actually) the aluminum FW unleashes, I personally wouldn't want to dismiss the Fidanza out of hand.
Your mileage may vary!
P.
I experience a lot of rattle at idle in neutral, and under light loads in gear. I do not/have not ever experienced any type of chatter or slippage. With that being said, the car is not my performance car, just a nice one to drive. I've been WOT twice since I've owned it. Just my .02
The attraction of the aluminum FW (for me) is the huge reduction of rotating mass; the DM stock weighs in around 43#, whereas the Fidanza is 13#. And, even in 4th gear (on a inertia dyno) the effective difference measures 15 hp; and would increase in proportion with the rate of acceleration - especially in 1st and 2nd gear where it might (I haven't done the math) be double+ 15 (effective) hp in 1st. I don't know what the dyno number is in first gear, but it makes a significant difference in first gear (especially), where the 315x35x17 (GY D3s) rear tires will break loose on the street almost at will w/o involving the clutch!
So, between your experiences with the D/f disc as it relates to using the Fidanza, and that I'm personally familiar with, I'd say something is causing it that might be one or a combination of things causing the problem. And, because of the "free horsepower" (torque, actually) the aluminum FW unleashes, I personally wouldn't want to dismiss the Fidanza out of hand.
P.
P.
You are right, There is no scientific evidence in my case that the aluminum flywheel is the root cause to the chatter in my car. I can say that I personally have very strong feelings that it is the cause because out of all my research regarding the matter (yes I use the internet as a tool) I didnt find any cases where the centerforce D/f clutch had any chatter issues when matched with a steel flywheel.
I did however find more than I can count on my fingers and toes where people have the same set up as mine and have the same dang issues. So maybe out of the 5 or 6 people you know and have personal phone numbers for lol
that have relatively close setups in their car using the fidanza didnt have the problem does not mean that it isnt a issue with a portion of the fidanza users weather it be the majority or a small few. Maybe as a previous poster said, it had to do with a PUCK style plate. I do not know and wont know until I pull mine out after it fails.I do agree tho that the Fidanza is obvioulsy lighter and less rotating mass equals more horsepower and a much faster reving engine.
And, no... I have no interest in Fidanza, other than I have recommended them to friends and others, and since there is an issue with at least some applications, I'd be curious to exactly what is going on, and what is it about the D/f - Fidanza that is apparently causing a problem - before recommending either the D/f or Fidanza. Knowwhaddimean??
Talk to Jim Jandik @ Powertorque.com
OR
RAM clutches and tell them the ZR-1 Registry sent ya.
OR
Your original post was regarding "ditching the dual mass" and NOT the "violent vibration". Perhaps your issue could be at the "other end" of the crankshaft and maybe the entire build is suspect. You mentioned you bought it this way it seems. You've mentioned nothing about "the build" and you've removed what are normally NOT parts that create issues when properly selected when the build is planned.
Do you know whose build the engine is? What is the engine build? What's on the other end for a balancer? That could maybe give you a hint as to what should be on the flywheel end of the crankshaft.
You assumed and tore it apart and I'd say the consensus from the parts images that you've displayed is "maybe" a sprung disc should have been chosen but that doesn't have anything to do with the violent shake.
I'd say you need to start from scratch and investigate the build.
OR
Thank you.
