One piece or "solid" flywheel
I nor anyone in our Chicago group has complained about chatter, that I'm aware of. Inertial dyno tests show an effective increase of approx 15 hp on a 500 hp LT5 due to reduction of rotating mass. These results are recorded in 4th gear, and would likely be more in the lower gears, due to the higher rate of rotational acceleration.
This is one easy way to get a real, cheap 15+ hp (a little less for a stock 300 hp LT1). The purpose of the dual mass was to absorb crankshaft pulse variations that otherwise cause the gear box to rattle a little when idling in neutral. However, raising the idle to approx 800-850 rpm pretty much ends the rattle. If rattle remains, then the injectors become suspect (and have been found to be the problem in most cases).
I love my Fidanza.
RAM Clutch has a new dual disc clutch assembly that some of the big inch LT5 guys are using. A nice feature too is it uses a ring slave cylinder that fits over the nose shaft of the transmission that acts directly on the fingers of the (push-type) RAM pressure plate, i.e., no "fork" is used.
Check with RAM regarding LT1/L98 applications and pricing. For the ZR-1s the dual disc kit was approx $1250, a year ago, FWIW.
P.
From what I understand the holes for the removable friction plate cause chatter from the edges when the harder composit pucks on the disk make contact with the plate.
OP keep us posted on how things work out, I got a few F Body FW and that might be and option when I do my car.
If he has the transmission he mentions the entire package is a "specialty" selection of pieces. The OP needs to do some research. In his original post he "hints" DMF but it's pretty obvious from his later comments that he actually didn't know. It's seems obvious that the OP didn't do the build. I would think that if someone went to the expense of a "True Transzilla" that it wouldn't have a "push style" clutch also. Not necessarily but likely!
I've put over 40k HARD miles on it. Just pulled the trans to replace the clutch as it was starting to slip. Got a new CenterForce D/F setup on the way.
The ZF does sound a lot like an old Muncie M-22 Rockcrusher at idle sometimes...but it was expected. The choice of fluids inside the trans can make a huge difference. I use the Castrol synthetic...once I went to it the shifts are smooth and the clatter is almost gone.
)When you said "pucks" I realized you're using one of those extra special grippy discs. In contrast, the Centerforce 381039 disc I/we use is a flat, sprung hub type and it works with the stock Veleo pressure plate AND the Fidanza, apparently.
Never had a moments problem with the Fidanza/Centerforce 381039 (sprung hub) disc/Veleo combo. (And there's a bunch of 'em running around in FBI land running north of 500 hp.) However! When you mentioned "pucks", the ONLY chatter problem one of us was having was with a single mass steel FW (not a Fidanza) and one of those "puck" type discs. Now you have me wondering if the maybe it is your disc too that is at the root of the chattering??
I dunno - just making an observation. I do know his was a pain to drive around town, as I recall. The ultimate cure to smooth operation w/o slipping was a dual disc RAM clutch conversion. The kit was built by RAM with the input from some ZR-1 guys, and the comment was made that "...for under 600 hp, it would be the last clutch you'll ever buy."
Getting off track a bit, but maybe worth looking into; a dual disc, whether it is made by RAM or CENTERFORCE or whomever might be the solution for your big hp application.
